Author Topic: Need help finding a keycap set  (Read 2801 times)
Offline Raptorsatan
  • What's that noise?
« on: Sun, 09 August 2015, 16:25:09 »
So, I just purchased a Filco MJ1 and am looking for new keycaps as this keyboard is second hand and the original a bit worn down. I'm specifically looking for something go with a blue/white/purple theme build I have going. I noticed the Keycool Gradient Keycaps on Massdrop but I am hesitant because of that damned typeface. Does anyone have a better suggestion?
The build in question is named Frostbyte, I've got sort of a winter theme going on with it. Heck I'd be ecstatic if I could find a few snowflake keycaps.
Edit: Better clarity to the theme of the build
« Last Edit: Sun, 09 August 2015, 20:22:57 by Raptorsatan »
CM Quickfire Mx Blue // Filco MJ1 NKRO 104 Mx Blue
Clakcity Clackity Clackity....
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
Re: Need help finding a keycap set
« Reply #1 on: Sun, 09 August 2015, 16:26:35 »
I have blank blue PBT IMSTO keycaps that fit Standard layout boards if blanks interest you.
Offline Raptorsatan
« Reply #2 on: Sun, 09 August 2015, 16:35:27 »
I really wish I could do blanks, I got a concussion in 2009 and am still getting the hang of touch typing again, I still have to reference my keyboard to reposition and find keys. from 104 WPM to 30 in one hit to the head.
Offline Oobly
« Reply #3 on: Mon, 10 August 2015, 07:59:01 »
A pity you missed the JTK debut sets: https://ctrlalt.io/buys/jtk-debut
You might like one of these sets:
http://www.reddit.com/r/MechanicalKeyboards/comments/35xoob/interest_check_dsa_keydset_by_mito/
http://www.pimpmykeyboard.com/deals/gravity/
Or if you can find one in the Classified, the Raindrop set is a nice white/blue combination. I'm sure there are others, but those are the ones that come to mind immediately.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline sth
  • 2 girls 1 cuprubber
« Reply #4 on: Mon, 10 August 2015, 08:02:33 »
There's also Olivetti (-inspired) sets out there - olivetti inspired will be cheaper probably.
Offline Raptorsatan
« Reply #5 on: Mon, 10 August 2015, 13:40:32 »
Wow It's a super pity that I missed the JTK Debut Series... the one thing that make it twice as difficult is that I have a full 104 keyboard and a lot of the sets people have are only the 87
Offline Oobly
« Reply #6 on: Thu, 13 August 2015, 05:45:57 »
You could contact BunnyLake and ask if there will be any extras available or post in the Group Buy thread (https://geekhack.org/index.php?topic=71630.0) to see if anyone is willing to sell their set to you. Sometimes a person will join a GB and then decide the set isn't for them and you get some transfers happening before the sets get shipped out.
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #7 on: Thu, 13 August 2015, 06:06:43 »
Good news, as far as I have heard, there will be extra JT debut sets once it finishes. I believe.
There is hope to be had!
