Author Topic: Novatouch silencing mod. sticking sound?  (Read 2562 times)
Offline awhitedev
« on: Mon, 10 August 2015, 07:18:22 »
So I modded my Novatouch using Spicebar's landing pad mod. I love the sound... except for two keys. My 'd' and '2' key make a slight sticking sound when they return... but only when I bottom out and let the key return to its resting position.  It's not something I really feel... it's just an annoying sound. I've tried taking the board apart and reseating it but that didn't really help. I also tightened the screws a little bit more thinking that maybe that would help... no dice.
Any thoughts you guys have would be helpful.
Offline Herothereu
Re: Novatouch silencing mod. sticking sound?
« Reply #1 on: Mon, 10 August 2015, 10:08:24 »
Air being trapped.
Offline awhitedev
« Reply #2 on: Mon, 10 August 2015, 11:42:32 »
Any idea how to fix that?
Offline wntrmt
« Reply #3 on: Mon, 10 August 2015, 15:44:01 »
As I plan on doing this exact same mod as soon as my landing pads arrive, I too would be very interested in a solution to this. Any ideas?
Offline awhitedev
« Reply #4 on: Wed, 12 August 2015, 08:17:35 »
So it seems like the sound is coming from the switch housing itself. I noticed that these two housings wiggle around a little more than the others. Any idea how to remove those? I obviously do not want to break the housing off the plate lol. I vaguely remember seeing a post somewhere where someone did this but I can't find it now.
Offline awhitedev
« Reply #5 on: Sat, 15 August 2015, 09:33:50 »
So it would appear the issue was with the switch housing itself. While performing the mod and pushing the sliders back in some of the housings became a little loose.
I had to remove the housings that stuck and apply a small amount of thick lube around the hole where the housing meets the plate. What a pain though.. While taking the housings out from the plate I noticed that some of the other switches became loose. I basically had to rinse and repeat this process several times until I got all of the them sounding good. If I had to do it over I'd just remove all the housings while doing the mod and just lube them all.
