Author Topic: Self-Sanitizing Keyboard  (Read 2290 times)
Offline itlnstln
« on: Mon, 12 October 2009, 16:19:27 »
Check it.  I guess this would be good for hospitals and such, but, uhh, yeah, and for around $900, I think I'll pass.
BTW, it's probably a rubber dome.
Offline itlnstln
« Reply #1 on: Mon, 12 October 2009, 16:35:20 »
Your method is a lot less expensive and works with many different already existing keyboards.  You should win the Nobel Peace Prize.
Offline AndrewZorn
« Reply #2 on: Mon, 12 October 2009, 16:37:11 »
No his method has done nothing he should be removed from this forum immediately
Offline JBert
« Reply #3 on: Mon, 12 October 2009, 16:41:43 »
Quote from: itlnstln;124787
There is a prize for medicine too, you know. I know the peace prize was a bit short of nominees, but sheesh, let's try to stick to the topic.
Also, $900 buys me a nice ergonomic keyboard. As most of those look weird, I'm sure nobody will even dare to use it.
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline itlnstln
« Reply #4 on: Tue, 13 October 2009, 07:53:56 »
I had a full gas can, and it was getting heavy.  I needed to pour some out.
