Author Topic: Zeal, do you have transparent Cherry MX switch case (both top & bottom)?  (Read 77027 times)
Offline quake4mhg
I saw someone brought some transparent switch top from you.
Because I wanna make a DSI left hand keyboard backlit, gonna try put LED stripe under the PCB, but need transparent switch case. Hope LED light shines thru.
BTW, are you in Vancouver? I can dropby and pick it up ;D
Offline Zeal
  • * Moderator
    • Zeal Generation Inc.
Re: Zeal, do you have transparent Cherry MX switch case (both top & bottom)?
« Reply #1 on: Thu, 13 August 2015, 01:29:03 »
The transparent switch top + bottom will be bundled with the Zealio switches, and not sold seperately. GB is expected to happen end of August. :)
Yes, I'm in the Vancouver/Richmond Area.
Offline quake4mhg
« Reply #2 on: Thu, 13 August 2015, 02:42:13 »
Awesome x2!!! Can't wait the GB! I can dropby & meet you :D
