Author Topic: What soldering wire should I get to build a keyboard?  (Read 3422 times)
Offline Steezus
  • Keeper of Facts
« on: Thu, 13 August 2015, 10:43:43 »
Title says it all, I tried looking around and found some people recommending Kester 44 Rosin Core Solder 63/37 .020 but the 1lb spool is pretty damn expensive on Amazon. I just want to see if there is better options out there, if not I'll just have to suck it up.
Offline jerue
  • (Whenever that happens :P)
Re: What soldering wire should I get to build a keyboard?
« Reply #1 on: Thu, 13 August 2015, 10:49:23 »
Use .050 for the assembly. .020 would be useful for diodes if you plan on putting those in your keyboard. I think 63/37 will be OK.
Offline Steezus
  • Keeper of Facts
« Reply #2 on: Thu, 13 August 2015, 10:58:10 »
All smds and diodes came pre-soldered so all I am planning on doing is switches with sip sockets. I haven't done too much electronic soldering but have done decent bit of copper soldering for drain systems in HVAC, two totally different types of soldering it seems like but same concept.
Offline retrochick
  • goodbye my wallet
« Reply #3 on: Thu, 13 August 2015, 11:05:32 »
I just use whatever Radioshack had. Something like .032 for switches and .022 for LEDs 60/40 rosin core.
Offline Steezus
  • Keeper of Facts
« Reply #4 on: Thu, 13 August 2015, 11:13:24 »
Thank you very much for your help, do I need to buy a 1lb spool for a 96% keyboard or would a 6oz spool be sufficient?
« Reply #5 on: Thu, 13 August 2015, 11:14:38 »
I prefer Kester but the Radio Shack stuff will work. 6oz should be fine for a board. 1lb is definitely overkill.
Offline retrochick
  • goodbye my wallet
« Reply #6 on: Thu, 13 August 2015, 11:18:35 »
Yes Cptn is right. 6oz is plenty. Good luck! Be sure to post your build log/progress pics.  :thumb:
Offline Steezus
  • Keeper of Facts
« Reply #7 on: Thu, 13 August 2015, 11:43:18 »
Thank you all for your help, I will make sure to document my voyage of keyboard building :D
