Author Topic: Did Keytronic make any mechanical boards?  (Read 6193 times)
Offline Blaise170
  • ALPS キーボード
    • XYZ
« on: Thu, 13 August 2015, 19:51:38 »
I've found a Zenith keyboard (http://www.ebay.com/itm/321447102689) that looks interesting but the OEM is Keytronic. Did Keytronic ever make anything that wasn't a rubberdome? The keycaps look pretty tall considering.
Offline Steezus
  • Keeper of Facts
Re: Did Keytronic make any mechanical boards?
« Reply #1 on: Thu, 13 August 2015, 20:14:06 »
I don't believe so, Keytronic was pretty popular for making surprisingly good rubber domes, some people prefer them for gaming actually because they're pretty close to an NKRO(They aren't NKRO but pretty good).
Offline Parak
« Reply #2 on: Thu, 13 August 2015, 20:42:49 »
Yeah.. it's not very well documented (I am the lazy), but they used to make reed switches:
http://imgur.com/a/KFnC2
Feel is unremarkably linear.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #3 on: Fri, 14 August 2015, 03:14:12 »
99.9% certain that thing is rubber dome. As is the Silitek one, and the three Honeywell ones on eBay.
« Reply #4 on: Fri, 14 August 2015, 17:19:13 »
Most keyboard by Key Tronic before the mid '90s had foam-and-foil switches.
They were either tactile with rubber dome or linear with a coiled spring - and you could exhange the rubber domes right under the keycaps for springs or vice versa. Sense is capacitative, but mushy ... and NKRO because: capacitative.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #5 on: Fri, 14 August 2015, 17:52:53 »
Ick. I'd use a rubber dome any day over their foam and foil. I had one of their foam and foil boards at one point, guess I forgot about those. I couldn't even give that board away for free.
« Reply #6 on: Sat, 15 August 2015, 06:07:25 »
Neither could I, at first. Then I donated parts to a restoration project for a more interesting keyboard.
Key Tronic was OEM for many companies. For instance, these are found in Sun Type 4 and the Apple Lisa keyboard.
