Author Topic: Linear spacebar?  (Read 3824 times)
Offline timw4mail
    • https://timshomepage.net
Linear spacebar?
« on: Tue, 13 October 2009, 07:02:20 »
After being fed up with the gray spacebar in one of my brown cherry keyboards, I replaced it with a black, linear switch I had around. I find a linear spacebar to actually be a lot more efficient than one with a tactile point. I think that for such an obvious key, the spacebar actually is impeded by a tactile switch. Thoughts?
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline JBert
Linear spacebar?
« Reply #1 on: Tue, 13 October 2009, 07:08:58 »
I don't mind the tactile point as much as its overall force needed to press. I tried to swap a brown under it, but that was just too light.
I need something in between a gray and a brown, maybe a clear switch would suit that description.
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline ironcoder
Linear spacebar?
« Reply #2 on: Tue, 13 October 2009, 07:10:49 »
That sounds pretty good although I tend to hammer the space bar pretty hard with my time worn thumb so any switch on the spacebar would probably work for me..
In the office: Filco 87 Cherry Browns x 2 (one with coffee damage, recovered) ● Lexmark IBM Model M 52G9658 1993 & 1996
Offline timw4mail
Linear spacebar?
« Reply #3 on: Tue, 13 October 2009, 07:22:33 »
Considering how much you use the spacebar, I don't find the tactile point to offer any advantage, really. With the exception of a buckling spring mechanism, a tactile switch really just seems to slow the speed at which you can actuate the spacebar.
Offline itlnstln
Linear spacebar?
« Reply #4 on: Tue, 13 October 2009, 08:27:38 »
Tactility doesn't bother me as much as force.  When I first got my MX11800, it had a grey switch for the spacebar.  I swapped it out for a brown from Scroll Lock or something and was much happier.  I can take or leave tactility.  My thumbs not sensitive enough to notice the tactlity on the spacebar unless I press it slowly.
Offline timw4mail
Linear spacebar?
« Reply #5 on: Tue, 13 October 2009, 09:07:57 »
Quote from: itlnstln;124936
When I got my MX11800, apparently the previous owner had done the same thing.
Really, I find the green switch in my Scorpius the most annoying, as its really sloppy if you want to use the spacebar for something like advancing text in an interactive novel.
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
Linear spacebar?
« Reply #6 on: Wed, 14 October 2009, 07:31:11 »
The space bar action is actually one thing that I like about G81s. A medium-weight linear switch should be pretty much perfect there. I can't see much of an advantage for tactility at this position either.
