Author Topic: autohotkey help  (Read 1926 times)
Offline Jixr
autohotkey help
« on: Mon, 17 August 2015, 17:08:05 »
Hi AHK peeps, I need help trying to figure out how to accomplish this.
I want my caps lock key to only work when its pressed and held down.
( similar to how a shift key would work )
Not sure how/if I could accomplish this with AHK
Offline Tactile
Re: autohotkey help
« Reply #1 on: Mon, 17 August 2015, 19:52:26 »
This might help...
http://www.autohotkey.com/board/topic/37117-shift-capslock-remapping-problem/
It looks like,to do what you want, you only need the line:
$Capslock::LShift
REΛLFORCE
Offline Jixr
Re: autohotkey help
« Reply #2 on: Mon, 17 August 2015, 19:56:09 »
capslock::lshift wont work since number inputs would be symbols.
Using an mx lock as my caps lock key.
Though this script works perfectly
capslock::
setcapslockstate on
keywait capslock
setcapslockstate off
return
