Author Topic: [MOD] Razer Orbweaver keycap compability mod  (Read 11206 times)
Offline Zorox
  • Tactile FTW <3
« on: Wed, 19 August 2015, 08:40:56 »
While the Orbweaver has a weird plate, it is not compatible with normal keycaps. So that I decide to trim the plate out :D
original mod was from here: http://watchmono.com/blog-entry-3902.html
and here is my work :D http://imgur.com/a/3sA8r
hope you guys enjoy it
Offline jerue
  • (Whenever that happens :P)
Re: [MOD] Razer Orbweaver keycap compability mod
« Reply #1 on: Fri, 11 September 2015, 13:25:07 »
Nice mod, and interesting choice to mod the plate rather than just make extenders for the keycaps. I've had certain Sadsters fit on my Orbweaver, since they have a longer stem than most caps.
Offline hippo008
« Reply #2 on: Mon, 14 September 2015, 19:26:20 »
Very professional looking. I like it
Offline louiscarter88
« Reply #3 on: Thu, 24 September 2015, 05:05:10 »
This is exactly what I'm thinking of doing. What tool did you use to cut the plastic? (google translate is terrible)
Offline Zorox
  • Tactile FTW <3
« Reply #4 on: Thu, 24 September 2015, 09:07:34 »
I use a hook-a-like plastic cutter like this one
and slide it slowly along the edges, with a good one like Olfa you can cut it down in 3-4 strokes, before it I used a side cutter to trim out the reinforcement under the plate.
Offline MyBoolean
« Reply #5 on: Wed, 14 October 2015, 19:28:45 »
nice mod.
