Author Topic: Best way to lube switches?  (Read 78445 times)
Offline awhitedev
« on: Wed, 19 August 2015, 09:13:21 »
I've usually lubed my springs and switches with a small brush. On your site I see that you sell lube in a syringe.  What's the best way to lube springs and switches with this? Do you just pump it into a small dish and apply with a brush or toothpick? Do you have any tips?
Offline infiniti
  • I <3 KB
  • Bob was here
Re: Best way to lube switches?
« Reply #1 on: Thu, 20 August 2015, 02:43:51 »
Personally, I like using a small hobby paint brush for better control.
If you haven't already, check out the Cherry MX Switch Lubrication Guide (https://geekhack.org/index.php?topic=34332.0). :thumb:
« Reply #2 on: Thu, 20 August 2015, 03:06:34 »
those needles with the brush tips are easily the best tools to apply lube with.
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #3 on: Thu, 20 August 2015, 09:36:48 »
I like this way better over the brush tips for the lube syringes
