Author Topic: Colortheme for a basekey set  (Read 1336 times)
Offline dan002
« on: Wed, 19 August 2015, 12:11:23 »
I'm referring to an image shown here because I like the base key set's theme. The options for the base key set are white, gray etc., however, which one should I choose to resemble the photo?  I'm looking for those white base keys with those matching grey modifiers.
Also , the DSA (medium) should be alright on a Cherry mx keyboard correct?
Have an excellent day,
Dan
Peace, love and keyboards.
Offline trenzafeeds
  • **** off
Re: Colortheme for a basekey set
« Reply #1 on: Wed, 19 August 2015, 12:21:02 »
If you want to match the photo you want the WAN base set, the GDE mods, and the WAN numpad.
Also, yes, DSA should work with any cherry board. The one thing you should check is your bottom row spacing, is yours standard?
demik will never leave.
Unless he gets banned.
Offline dan002
« Reply #2 on: Wed, 19 August 2015, 13:29:29 »
I think they are becuase all the keys on the bottom row of my Cherry Board 6.0 are the same width. There are three too the left of the spacebar plus four on the right. I found two awesome poly carbonate that I shall use for the alt keys next to the space bar. Check it out...
These keyscaps are awesome, they're from Originative
108761-0
A picture of the home row.
108759-1
Offline trenzafeeds
  • **** off
« Reply #3 on: Wed, 19 August 2015, 13:34:30 »
Yep, everything looks standard, you should be totally fine.
