Author Topic: Northgate Omnikey 101, two missing switches, $40 shipped  (Read 4740 times)
Offline ander
  • I type, therefore I am
« on: Wed, 19 August 2015, 21:53:44 »
OMNIKEY 101 NORTHGATE KEYBOARD
The seller (100% positive eBay rating) says, "Keyboard works but it's missing some keys." Specifically, it's missing two caps and one actual switch:
108827-0
Seems like an opportunity, as these commonly go for over $100 complete.
Offline RigorVN
Re: Northgate Omnikey 101, two missing switches, $40 shipped
« Reply #1 on: Sun, 06 September 2015, 03:11:03 »
Do northgate omnikeys really go for $100+? Why so much?
Offline jacobolus
« Reply #2 on: Sun, 06 September 2015, 03:24:22 »
Lots of old Alps keyboards from the same era have funky layouts, or use ADB or XT protocol which need a custom converter. Some people really like having an ANSI/101 layout keyboard that you can trivially get working with a modern computer.  They have dip switches for swapping left control and caps lock and a few other options.
Omnikeys are also built like tanks, with a solid metal back and thick plastic front. They are as sturdy as any Alps board you can find.
Offline RigorVN
« Reply #3 on: Sun, 06 September 2015, 12:59:18 »
but aren't dell AT101W's also alps and easily used with modern computers?
Offline jacobolus
« Reply #4 on: Sun, 06 September 2015, 21:13:50 »
An old-logo Dell AT101 with salmon Alps switches sells for about the same as the Northgate, despite having a much less beefy construction. A Dell AT101W can be had for cheap because there were many millions of them produced, and they are even less sturdy, have pad-printed keycaps, and less desirable “bamboo” black Alps switches from the mid-90s. They are inferior to the Northgate in every respect, unless you care strongly about the Win key.
« Last Edit: Sun, 06 September 2015, 21:17:16 by jacobolus »
Offline RigorVN
« Reply #5 on: Sun, 06 September 2015, 21:46:04 »
ah, i see. So would $50 for a like new omnikey 101 be worth it then?
« Reply #6 on: Mon, 07 September 2015, 11:51:32 »
$50 would be a good deal.
Ugly yellowed copies often sell in the >$70 shipped price range.
« Last Edit: Fri, 11 September 2015, 08:00:22 by fohat.digs »
- D Trump 2026-10-24
Offline Hak Foo
  • Make America Clicky Again!
« Reply #7 on: Mon, 07 September 2015, 11:55:58 »
Jacobolus:  The AT101W features lasered caps-- very old-school early ones where the lettering isn't dark and is often inconsistent in shape.  Not pad printed: worse.
Overton130, Box Pale Blues.
Offline jacobolus
« Reply #8 on: Mon, 07 September 2015, 13:22:20 »
Ah that’s right, thanks for the correction. (I’ve never had a Dell AT101.)
« Reply #9 on: Mon, 07 September 2015, 13:32:33 »
I have had AT101s, both old logo and new. Only one, a new logo, had PBT caps, out of at least 4. I did not keep the old logo one long enough to examine the switches, I had really bought it (from Cindy) just to harvest the caps, and they were not what I wanted.
The ones that I have kept were black AT101W (cases) into which I transplanted switches (and weight bars) and one of them has the PBT caps (except for the bottom row, where I had to use the ABS to get Windows keys). I also have at least 2 stock AT101Ws awaiting future projects.
Offline ander
« Reply #10 on: Wed, 09 September 2015, 18:53:18 »
AT101Ws have Alps Black switches, while Northgates have Alps White. Whites are smooth and clicky (esp. the older "complicated" ones found in Northgates), while Blacks are a cheaper linear version that usually hasn't held up as well over the years.
Offline RigorVN
« Reply #11 on: Wed, 09 September 2015, 19:08:39 »
hmm.. so it seems like the omnikey is pretty worth it eh
Does it really hover above $100 usually though? that sounds insane... price range of Model F's
Offline njbair
    • nickbair.net
« Reply #12 on: Wed, 09 September 2015, 22:30:54 »
If this had blue alps I'd be all over it. Need some blues!!!
My boards:
« Reply #13 on: Thu, 10 September 2015, 07:24:36 »
The Omnikey 101 sells around the same price range as the other Northgates.
« Last Edit: Fri, 11 September 2015, 08:01:15 by fohat.digs »
