Author Topic: Any keyboard with this layout? TKL touchpad  (Read 4081 times)
Offline Wilkie
« on: Thu, 20 August 2015, 15:10:04 »
Are there any keyboards with this layout or something very similar?
Key feature is touchpad above arrow keys on TKL. Thanks.
Re: Any keyboard with this layout? TKL touchpad
« Reply #1 on: Thu, 20 August 2015, 15:48:25 »
Closest thing I can think of is the 1800 that has the touch pad.
Offline Hzza
« Reply #2 on: Thu, 20 August 2015, 16:07:34 »
It's the 11900 that has the touch pad ;).
Shouldn't be too hard a mod if you get a Phantom and on of these, in theory....
Offline Wilkie
« Reply #3 on: Thu, 20 August 2015, 16:20:08 »
Thanks, CPTBadAss and Hzza.  Phantom is intriguing, looks like it would support this layout.  Will investigate this further.
Offline Data
« Reply #4 on: Thu, 20 August 2015, 16:33:04 »
Not a bad idea, but it would require 2 cables. :(
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #5 on: Thu, 20 August 2015, 16:36:44 »
Why is Insert and Delete one key?  That makes no sense to me.
Offline Wilkie
« Reply #6 on: Thu, 20 August 2015, 16:45:05 »
I don't see anything wrong with putting it there.  I'm used to Insert being above Delete, now I only have to Shift-Delete (and I don't use Shift-Delete for anything else).  Rarely use Insert, though, so wouldn't lose much by dropping it, either.  In any case, the main question about the layout is the touchpad placement above the arrow keys.
Offline Snowdog993
« Reply #7 on: Thu, 20 August 2015, 16:56:47 »
So Home - End is more important than Insert - Delete?
It's your keyboard.
Edit: I find this very odd in my opinion.
« Last Edit: Thu, 20 August 2015, 17:15:18 by Snowdog993 »
Offline Data
« Reply #8 on: Thu, 20 August 2015, 20:35:04 »
Shift+Delete is a legit Windows command. I use it all the time.
Offline Snowdog993
« Reply #9 on: Thu, 20 August 2015, 21:56:10 »
Yeah okay.  I just feel that the Ins/Del keys should be where the Home/End and vice versa.  Not that it's a legit keypress for it.
Offline Wilkie
« Reply #10 on: Fri, 21 August 2015, 09:42:53 »
Yep, I use Home and End much more often than Insert or Delete, not even close.
Offline zars15
« Reply #11 on: Sat, 22 August 2015, 06:26:13 »
It's your keyboard.
I guess it depends on what you do. Before switching to vim and homerow style, I used them often when programming.
« Reply #12 on: Sat, 22 August 2015, 07:56:12 »
There are a bunch of vintage keyboards with a trackball where the arrow cursor keys usually go.
I think I would prefer a trackpad in front of arrow cursor keys, only because of physical mouse buttons on the front of the case.
