Author Topic: hot-swapping converted keyboards  (Read 1635 times)
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« on: Fri, 21 August 2015, 04:04:42 »
So you're not supposed to hot-swap PS/2 keyboards, right? But you CAN hot-swap USB keyboards. So, can you hot-swap a PS/2 keyboard with an active USB converter at the end, or will you still risk damaging the keyboard?
Offline Ludovician
Re: hot-swapping converted keyboards
« Reply #1 on: Fri, 21 August 2015, 06:06:20 »
No, you're fine to hot-swap them with USB.
Typing speed:
My collection:
HHKB Pro 2 (Blank, white) | HHKB Pro 2 Type-S (Blank, white) | Topre Realforce 87UB silent-modded (not currently functional) | Das Keyboard Model S Professional Silent (MX Brown) | IBM Model M 1391401 - 9th January 1991 (Bolt+Floss-modded) | Apple keyboard m0116 (Orange Alps) | Unidentified DIN Keyboard (White Alps) | ADDS 1010 (Green Alps) | AEK II (Linear-modded, USB-converted) | IBM PC-AT Model F | Noppoo Choc Mini (MX Black) | Amstrad PC2286 | BigKeys LX | IBM Model M 1391401 - 6th September 1990 | IBM Model M2 1395300 - 28th February 1991 | Leopold FC660C | Cherry G80-11802 (MX Brown) | Matias Tactile Pro (Simplfied grey Alps) | Razer Blackwidow (MX Blue) | Novatouch 55g | Focus FK-2001 (White alps) | DSE Multitech (Blue alps) | Dell AT101W (Matias quiet) | Pok3r (White w/Clears) | KBP V80 (Blue Alps)
Pending:
Infinity kit
« Reply #2 on: Fri, 21 August 2015, 07:18:39 »
Somewhat off-topic, but if Soarer's Converters are involved, and you try to add a 2nd one, it won't work.
Only the first Soarer's Teensy is recognized at a time.
- D Trump 2026-10-24
Offline chyros
  • a.k.a. Thomas
« Reply #3 on: Fri, 21 August 2015, 07:19:36 »
Cool, and what about if you use just a simple adapter rather than a converter?
