Author Topic: Cherry G81 "NCR Germany Keyboard 3299-K420-V002 1989"  (Read 4223 times)
Offline Eugene45
« Last Edit: Sat, 22 August 2015, 11:24:06 by Eugene45 »
lmao, cut the French some slack, they gave you a big statue
Offline Eugene45
« Last Edit: Sun, 23 August 2015, 08:23:04 by Eugene45 »
Offline ComradeSniper
  • HHKB Pro
Re: Cherry G81 "NCR Germany Keyboard 3299-K420-V002 1989"
« Reply #2 on: Sat, 22 August 2015, 20:35:50 »
found this too : http://www.ebay.com/itm/Vintage-NCR-KEYBOARD-/301718496820?hash=item463fd2e634
Aww, at first glance I thought this was a G81-3007. Looks like rubber domes, though.
Offline XMIT
  • formerly jsoltren
« Reply #3 on: Sun, 23 August 2015, 08:22:12 »
Definitely rubber dome. I have one just like it in the garage.
Offline engicoder
« Reply #4 on: Sun, 23 August 2015, 09:02:48 »
found this too : http://www.ebay.com/itm/Vintage-NCR-KEYBOARD-/301718496820?hash=item463fd2e634    RUBBER DOME
This one has been on Ebay for months, torturing me with its insufficiencY
Offline Eugene45
« Reply #5 on: Sun, 23 August 2015, 09:06:24 »
Likely to harvest the plastic case ?
Or can you salvage more thing ?
Offline ghostjuggernaut
« Reply #6 on: Sun, 23 August 2015, 10:01:47 »
The Cherry G86 boards are not compatible with aftermarket PCBs.
Offline engicoder
« Reply #7 on: Sun, 23 August 2015, 16:46:40 »
It looks great, but the guides for the rubberdome caps are molded as part of the upper case, so it would be VERY difficult to re-purpose for use with PCB.
Offline REVENGE
« Reply #8 on: Mon, 24 August 2015, 22:51:31 »
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #9 on: Tue, 25 August 2015, 10:55:36 »
Actually, the older G83 used the same G80/G81 casebody and a seperate piece for the slider palte. If it dosen't have the indentation around the cursor keys it's the old type. Later on they made a new casebody where the slider 'plate' is integrated with the top.
