Author Topic: Blue or neutral aluminium case that fits Phantom Boards  (Read 1643 times)
Offline Amr0d
« on: Mon, 24 August 2015, 21:56:49 »
I am looking for a nice case for my Phantom because I might get hands on my MX blue since Profosists GB has been taken over by someone else and then I might be able to finish my Phantom. I had a look at this: https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=212 But it seems that it doesn't fit. Are there any other (not so expensive) aluminium cases? Can be a blue one as well because I am using the Raindrop keycap set. Thanks for helping
Filco MJ2 TKL browns | Race 75% LE reds | Phantom GH Edition soon™
HeatWare
Offline samhwang
Re: Blue or neutral aluminium case that fits Phantom Boards
« Reply #1 on: Sun, 06 September 2015, 02:25:14 »
You just missed the group buy on Deskthority. To sum up it was a group buy for both the plate and the bottom piece case as well, giving the Phantom a "naked" look.
http://deskthority.net/group-buys-f50/ansi-iso-jd40-styled-plate-case-t11302.html
Otherwise, I don't think there would be a Aluminum TKL case that can fit a Phantom that is actually on the market at the moment. You can try the Vortex case, but it needs a LOT of modifications.
