Author Topic: How good is BLE for keyboards? Anyone trying this yet?  (Read 2145 times)
Offline mrflow3r
    • T
« on: Wed, 26 August 2015, 23:33:56 »
Ok, I get the standard/classic BT modules consume too much power to be used as keyboard controllers.
I think I have read 12 hours is usually what we get with the combination of a Teensy + Bluefruit EZ Key.
Well, it's 2015 and I see a number of BLE modules in the market. One being Rigado's BMD-200 [1].
On their specification page [2], it says it consumes 5.5mA @ -20dBm for TX, and 2.4mA @ 16Mhz for the CPU.
Off the top of my head, Bluefruit EZ Key alone uses 25+mA. So these numbers look pretty good.
I ordered a BMD-200, and made a breakout board[3], so I will try to find out the numbers in a few days (hopefully, if I can get my head wrapped around BLE).
That said, is this even the right tech to use? I heard proprietary radio protocol gets *months* of use time (the ones we find in Logitech kbds...).
So perhaps that's what we should aim for, rather than these general purpose BLE stuff?
[1] https://www.rigado.com/product/bmd-200/
[2] https://www.rigado.com/product/bmd-200/#55de7bc5f1311-1
[3] https://oshpark.com/shared_projects/f1aGKcII
Offline twiddle
    • Portfolio
Re: How good is BLE for keyboards? Anyone trying this yet?
« Reply #1 on: Thu, 27 August 2015, 05:48:08 »
I've heard some good things about the Nordic nRF51822 BLE solution. I'm still doing a fair bit of work on my actual firmware implementation before I get to looking at BLE, but I've got a devkit ready for when I'm at that point.
BLE is a *very* different protocol compared to Classic BT in terms of how it consumes power, so I think you'll find the results are quite positive.
Here's a very trivial, untested power consumption estimation for the NRf chipset:
As you can see, even with very high connection frequency, we still get about 9 days battery life from a 220mAh battery. If we combine that with USB charging functionality, which isn't *too* difficult to implement from my preliminary research, that seems quite acceptable to me.
The primary disadvantage of the proprietary protocols is a lack of universal support. I use tablets and iPads often enough that I think being compatible with those is a definite plus, and you aren't likely to find a Shockburst or other proprietary protocol that works with that sort of device.
Offline mrflow3r
    • T
« Reply #2 on: Thu, 27 August 2015, 11:22:09 »
Thanks twiddle for ur response! It looks like BLE is a good choice for the time being. *9 DAYS* of juice on paltry 220mA battery! I may still look for Rf development, but BLE could just do the job looking at your  numbers. Btw what's the estimation tool you are using?
« Last Edit: Thu, 27 August 2015, 11:23:40 by mrflow3r »
Offline twiddle
    • Portfolio
« Reply #3 on: Mon, 07 September 2015, 20:43:13 »
I was just using the official software from Nordic themselves, theres an estimation function included.
