Author Topic: Varmilo VA87M & VB87M, Keycaps, PBT Spacebar - ARRIVED  (Read 97667 times)
Offline HendyZone
  • HHKB Elite
  • * Moderator
    • MechanicalKeyboards.co.id
« on: Thu, 27 August 2015, 10:20:00 »
We will carrying Varmilo mechanical keyboard from now on and forever :p
It's very great and solid board
I already test some sample from them, including their colorful PBT keycap
If you know that Varmilo ever comes with costar stabilizer, from now on they didn't use costar stabilizer anymore
all comes with cherry stabilizer. The cherry stabilizer not mushy on this varmilo, like they modified the stab. Same technique use on Ducky One, Ducky Shine 5, NT108 as far as i know
On September we will have incoming Varmilo inventory
- VA87M
- VB87M (Cheaper Version)
- a lot of colorful varmilo keycap set
- PBT spacebar
You guys can browse the products later on here -> http://mechkeyboards.id/varmilo
We will update when the stocks is coming
« Last Edit: Wed, 21 October 2015, 06:45:19 by HendyZone »
Offline Lepidus
Re: Varmilo VA87M & VB87M, Keycaps, PBT Spacebar - ETA Mid September 2015
« Reply #1 on: Thu, 03 September 2015, 19:39:32 »
Nice! What about that 660M bluetooth varmillo sold a while ago, its really gone forever?
Also, will you have KULs restocked anytime soon?
Offline trenzafeeds
  • **** off
« Reply #2 on: Thu, 03 September 2015, 20:20:58 »
I feel like at one point you could purchase varmillos with gaterons. Will that be an option from you guys?
demik will never leave.
Unless he gets banned.
Offline HendyZone
  • HHKB Elite
  • * Moderator
« Reply #3 on: Fri, 04 September 2015, 03:14:38 »
So far yes no 660M they make again
KUL restocks on this month should be arrived :cool:
Yes majority comes with Gateron switch ;)
Offline Lepidus
« Reply #4 on: Wed, 21 October 2015, 06:02:47 »
Hey, Hendy
Will Va87m arrive anytime soon? Will it be the backlit version?
Offline HendyZone
  • HHKB Elite
  • * Moderator
Re: Varmilo VA87M & VB87M, Keycaps, PBT Spacebar - ARRIVED
« Reply #5 on: Wed, 21 October 2015, 06:48:44 »
Hey, Hendy
Hello, actually some VA87M already arrived and half already sold out by local customers;
since we are still developing the options + variants system for ordering through the site, we haven't listed the VA87M yet
In varmilo as you know; there are a lot of option and variants as an add-on
OEM keyboard but super complex :))
What kind of VA87M do you want ?
Switch ?
LED ?
Keycap ?
Case ?
Offline njbair
    • nickbair.net
« Reply #6 on: Wed, 21 October 2015, 07:02:03 »
This would be a great board for me if it was compatible with Mac. But it does some weird thing where it acts like multiple keyboards when you plug it in (probably for high KRO support), and Mac just chokes on this. It also means you can't use hasu's USB to USB converter, so no programmability.
I even tried using a USB to PS/2 adapter, back into a PS/2 to USB adapter. Nothing.
My boards:
Offline Lepidus
« Reply #7 on: Wed, 21 October 2015, 07:32:44 »
Hey, Hendy
Switch ?
LED ?
Keycap ?
Case ?
Switch ?
Gaterons browns/blues, probably. Actually, the cheaper the better, as I will put Zealios on it.
LED ?
Red leds.
Keycap ?
Are those black on black deysub already avalible? If not, the regular black on grey dyesub top printed.
What options other options you have?
Case ?
Again, what options are avalible? Maybe grey if there is any, or just regular black.
Thanks.
Offline HendyZone
  • HHKB Elite
  • * Moderator
« Reply #8 on: Wed, 21 October 2015, 08:08:00 »
Yeah varmilo is great board,
The early varmilo boards are not compatible with Mac
Do you know that Varmilo keyboard already compatible on Mac OS X now ?
Both of VA87M and VB87M are compatible on Mac
Switch ?
LED ?
Red leds.
Keycap ?
Case ?
Thanks.
Since you want to replace the switch; my suggestion is buy the cheapest Varmilo version then
the cheapest option is like this
va87m
gateron switch
black case
dark gray keycap (side printed)
no LED
you can add the LED by yourself
in this case you must wait around early december; we have this cheap varmilo version shipment on november including the Black on Black Dye Sub Keycap set
Offline njbair
    • nickbair.net
« Reply #9 on: Wed, 21 October 2015, 08:11:25 »
Yeah it works, i tested use regular PS/2 adapter on my PC :cool:
« Last Edit: Wed, 21 October 2015, 08:20:37 by HendyZone »
My boards:
Offline HendyZone
  • HHKB Elite
  • * Moderator
« Reply #10 on: Wed, 21 October 2015, 08:21:50 »
sorry i messed up modify your message :blank:
yeah VA87M works on PS/2
Offline Lepidus
« Reply #11 on: Wed, 21 October 2015, 08:36:19 »
va87m
gateron switch
black case
no LED
So, does regular version PCB support DIY leds? Thats very good to know.
Guess I will wait then. Those black on black dyesub look very nice.
Offline HendyZone
  • HHKB Elite
  • * Moderator
« Reply #12 on: Wed, 21 October 2015, 21:00:34 »
va87m
gateron switch
black case
no LED
Yes, the pcb between regular version is the same with LED version
So people can add LED on Varmilo by themself :cool:
Offline Jhonan
  • Chicks love duck pics...
« Reply #13 on: Sun, 25 October 2015, 12:44:09 »
Any plans on va108s?  (I think that's the full size name)
Offline HendyZone
  • HHKB Elite
  • * Moderator
« Reply #14 on: Mon, 26 October 2015, 23:28:49 »
Yes, of course
But we are waiting for the new models;
Varmilo still developing the new models for the fullsize board (detachable cable) and maybe low profile case too ;D
Offline Jhonan
« Reply #15 on: Fri, 30 October 2015, 12:03:36 »
Thanks for the update!
Offline razorsharpgears
  • TheOriginalBecker
    • Becker's 市場 рынок Markt - Sell/Buy/Trade
« Reply #16 on: Wed, 09 December 2015, 23:44:08 »
is there a way to see a list of the available Varmilo keysets? Can't seem to find them, and really interested in a few :p
Here at GeekClack, time isn't worth anything because CCs are money.
"You cannot plan the future. Only presumptuous fools plan. The wise man steers."
— Cosmo Lavish
|WTB/T/S| Thread ←Link
Offline HendyZone
  • HHKB Elite
  • * Moderator
« Reply #17 on: Sun, 13 December 2015, 18:43:41 »
Sorry just replied,
We will listed all of them soon
Still haven't finished the photograph, too many varmilo keyset :p
PM me what are you looking for  ;)
