Author Topic: Mechanical Keyboards 75% Board  (Read 106171 times)
Offline itskuroi
« on: Thu, 27 August 2015, 16:59:00 »
WHEN DID YOU GUYS ANNOUNCE THIS?!
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1379
Just take my money. (when i get the money for this next week  :p)
also i hope bot is standard in terms of space bar D:
« Last Edit: Thu, 27 August 2015, 19:20:44 by deleonhle »
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Moderator
  • The 00verseer of Vault 77
    • Mechanical Keyboards
Re: Mechanical Keyboards 75% Board
« Reply #1 on: Thu, 27 August 2015, 20:23:34 »
You just did! Hehe...thanks.
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Offline dante
« Reply #2 on: Fri, 28 August 2015, 12:31:45 »
Uhhhh... I must be missing it ... Where is the delete key on this?
Offline JoshMK
  • * Commercial Vendor
  • MechanicalKeyboards.com
« Reply #3 on: Fri, 28 August 2015, 12:48:46 »
Right Arrow + Backspace
It's still in production. I'll see if they can make it Fn+BS
Josh McConnell
Josh@mechanicalkeyboards.com
615.266.1420 ext303
Offline dante
« Reply #4 on: Fri, 28 August 2015, 13:09:50 »
I'm willing to overlook the font because the description says they are doubleshot keycaps but I think that embedding the delete on a 75% is a bad move.  I'd put the delete above the right arrow key, shift all the navigation (home/end/pgup/pgdown) one row up and make the scroll lock an embedded key.
Ask around before they put these in boxes ....... :/    I think the expectation is to have as little embedded functionality as possible in a 75%, 60% is a different story...
Offline Data
« Reply #5 on: Fri, 28 August 2015, 13:24:52 »
I put Del over the Home key on mine.  Where Scroll Lock is on the MK board is a special function key on the Octagon.  I don't remember if it would let me assign normal Scroll Lock to that switch or not, but that location makes more sense for Delete than the Pause/Break key.  I never, ever use Scroll Lock.  :p
Offline Phirr
  • If you don't work you die.
« Reply #6 on: Fri, 28 August 2015, 13:58:29 »
They have the other styles of gateron switches as well, along with greetech switch ones and ones with blue leds and white cases
Offline wildontara
« Reply #7 on: Sun, 30 August 2015, 10:30:56 »
is there a left ctrl/caps lock switch on this board?
Offline inkwell
« Reply #8 on: Tue, 01 September 2015, 14:36:34 »
Any update on this?  Also, what size space bar and right shift is that?  Trying to see how easy it will be to put keysets on this.  Thanks!
« Reply #9 on: Tue, 01 September 2015, 14:38:44 »
From a glance I'd guess:
Spacebar = 6.25x
Right shift = 1.75x (Cherry 1800 style short shift)
Offline 00zeRO
  • * Moderator
« Reply #10 on: Tue, 01 September 2015, 14:43:18 »
Spacebar = 6.25x
Yes, and yes.
Offline merlin64
    • MechMerlin
« Reply #11 on: Fri, 11 September 2015, 11:13:20 »
Anymore info on this?
1. Plate mounted?
2. Are switches able to be changed without de-soldering
3. Is USB cable detachable
4. Anyone got a sample copy by any chance?
5. What OEM actually makes it?
6. Any keys programmable?
Thanks
Offline 00zeRO
  • * Moderator
« Reply #12 on: Fri, 11 September 2015, 11:16:49 »
1. Plate mounted?
Thanks
1. Plate mounted? Yes.
2. Are switches able to be changed without de-soldering. No.
3. Is USB cable detachable. Yes. We have.
4. Anyone got a sample copy by any chance? Yes.
5. What OEM actually makes it?  :-X
6. Any keys programmable? TBD
Offline saturnotaku
« Reply #13 on: Fri, 11 September 2015, 11:42:46 »
The legends look similar to those on the Royal Kludge RC930 RGB.
I know there's a ? in the spec sheet, but do you know if these keyboards will be Mac compatible?
Offline merlin64
    • MechMerlin
« Reply #14 on: Fri, 11 September 2015, 11:43:03 »
Wow, your quick responses are very much appreciated =)
Could you at least tell us what country its manufactured in?  :) pretty please??  :) :) :)
Also would it be possible to see pictures of the underside of the keyboard? Thanks again.
Offline 00zeRO
  • * Moderator
« Reply #15 on: Fri, 11 September 2015, 11:44:47 »
Probably, but as for specific Mac functions (i.e. Command, Option, Return, etc), doubtful.
Offline 00zeRO
  • * Moderator
« Reply #16 on: Fri, 11 September 2015, 11:46:16 »
It would give it away.
Underside pictures of current samples would definitely give it away...hehe
Offline JoshMK
« Reply #17 on: Tue, 06 October 2015, 10:08:53 »
Just a small update; the "Delete" key will now be on the top right of the board where the "Pause/Break" is now. The "P/B" is now a function layer and the "Delete" is the primary/normal layer.
Keyboards have begun production, there was a bit of work with odds and ends. We expect these later this month or early November.
Josh McConnell
615.266.1420 ext303
Offline dante
« Reply #18 on: Wed, 07 October 2015, 21:34:25 »
What kind of warranty will these have?
Offline JoshMK
« Reply #19 on: Thu, 08 October 2015, 14:49:54 »
1 year from the date of purchase.
Josh McConnell
615.266.1420 ext303
Offline itskuroi
« Reply #20 on: Thu, 29 October 2015, 13:37:53 »
another delay :'(
Offline Delirious
« Reply #21 on: Thu, 29 October 2015, 13:57:14 »
Is there an online manual or at least some info on dip switch, if it has any?
Offline 00zeRO
  • * Moderator
« Reply #22 on: Thu, 29 October 2015, 13:59:01 »
No DIP switch, and no manual as of yet.
Offline matrixenigma1
« Reply #23 on: Sat, 09 April 2016, 14:15:08 »
« Last Edit: Mon, 20 April 2020, 08:39:28 by matrixenigma1 »
Offline 00zeRO
  • * Moderator
« Reply #24 on: Sat, 09 April 2016, 17:14:08 »
Can we expect Gateron switches in the near future? :)
Possibly. Have you ever typed on Greetechs?
