Author Topic: Lubing an HHKB  (Read 2621 times)
Offline TastaturenAuslese
  • Formerly temence
  • life marrow suckerer
Lubing an HHKB
« on: Fri, 28 August 2015, 21:58:50 »
Soooo... I'm going to be opening up my HHKB to do some lubing on the stems as they're starting to feel a bit scratchy. I kind of know where to put the lube, but can you guys help me figure out what consistency of lube I should use?
I got the Geekhackers lube kit that came with the (1) super runny, looks like water, lube (2) somewhat thick, but also still quite runny, looks like milk, lube and (3) super thick, doesn't really run, looks like glue, lube. Which one should I be using for the stems? Am I right that it should be number 2?
Home: Kishsaver - IBM 6019284/F62 | Work: HHKB Professional 2 Silenced | Temporary Retirement:
IBM '89 1391401 Merrill Lynch Financial Edition
They are a functional and practical indulgence.
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
Re: Lubing an HHKB
« Reply #1 on: Fri, 28 August 2015, 23:11:54 »
From brocaps in an older thread:
That is the only place you should lube them to keep from making a terrible mess. Use a mixture of 205 grease and maybe 103 GPL, 50/50 mix. You can use a q-tip to spread it inside the corner nice and evenly.
Air tree: I do think just a thicker lube is fine, mixtures is what bro recommends, but I have heard people have great results with just a thick lube.
CTRL alt will have some lube up on their store once it launches, so it might have the ideal lube you might want.
  • Formerly temence
Re: Lubing an HHKB
« Reply #2 on: Fri, 28 August 2015, 23:27:43 »
Thank you thank you. With the thicker lube, do you mean as thick as topre stabilizer lube?
Offline Air tree
Re: Lubing an HHKB
« Reply #3 on: Fri, 28 August 2015, 23:45:36 »
Just regular thick lube should do it, for all the keys on the board.
The thick lube sold by techkeys should work just fine.
http://techkeys.us/collections/accessories/products/krytox-switch-lurbricant
  • Formerly temence
Re: Lubing an HHKB
« Reply #4 on: Fri, 28 August 2015, 23:46:18 »
Yay, thanks :)
Offline ImpendingxDoom
  • MF the SuperVillain
Re: Lubing an HHKB
« Reply #5 on: Fri, 28 August 2015, 23:47:12 »
+1 would recommend the regular thick for topre
  • Formerly temence
Re: Lubing an HHKB
« Reply #6 on: Fri, 28 August 2015, 23:48:54 »
Are either of you familiar with the 3 lubes that came in Mkawa's goody bag?
