Author Topic: How loud are Dampened Cream Alps?  (Read 3996 times)
Offline TastaturenAuslese
  • Formerly temence
  • life marrow suckerer
« on: Tue, 01 September 2015, 01:26:31 »
New question:
So I've found a donor AEK II board from a local e-recycling depot, for my upcoming Alps 60% project. From someone with experience using these, how loud are the switches? I'm intending to use this board at work, since my original plan was to use my HHKB, but I kind want to leave it and the expensive artisans at home. Always wanted to have a cream Alps board though, so I thought it'd be great idea to build one for work. I just wouldn't wanna annoy my coworkers with all the clicky clicky. Thoughts?
Old question:
Looking to build a custom keyboard for work with some damped cream alps I've harvested. Can anyone tell me which customs I should be looking for? If I'm correct, the two that I know of are the Infinity and the JD40. Are there any other ones?
« Last Edit: Tue, 01 September 2015, 03:36:18 by temence »
Home: Kishsaver - IBM 6019284/F62 | Work: HHKB Professional 2 Silenced | Temporary Retirement:
IBM '89 1391401 Merrill Lynch Financial Edition
They are a functional and practical indulgence.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
Re: Which customs are alps compatible?
« Reply #1 on: Tue, 01 September 2015, 01:34:50 »
If you don't mind hand wiring, you can use Swills plate building tool for your own layout.
  • Formerly temence
« Reply #2 on: Tue, 01 September 2015, 01:36:15 »
Hmm, I don't think I'm keyboard savvy enough to handwire. I'd probably prefer something with a PCB already :3
« Reply #3 on: Tue, 01 September 2015, 01:37:53 »
Kingsaver
Infinity
I think some of duck's stuff is also
Offline sth
  • 2 girls 1 cuprubber
« Reply #4 on: Tue, 01 September 2015, 01:41:23 »
Hasu has a 60% pcb that he does groupbuys for sometimes
« Reply #5 on: Tue, 01 September 2015, 02:55:52 »
For the record the JD40 isn't Alps.
Handwiring really isn't that hard, don't buy a thin case though or getting it in will be!
  • Formerly temence
« Reply #6 on: Tue, 01 September 2015, 03:04:36 »
Ah I see. I must've misread then. JD45? I thought I saw Joey Quinn posting on the Price Check thread that he had either a JD40/45 with Blue Alps?
« Reply #7 on: Tue, 01 September 2015, 03:07:17 »
Could be, all I know is I have a JD40 and it isn't :)
  • Formerly temence
« Reply #8 on: Tue, 01 September 2015, 03:07:51 »
Just double checked, my bad, it's the JD45 haha.
  • Formerly temence
Re: How loud are Dampened Cream Alps?
« Reply #9 on: Tue, 01 September 2015, 03:36:27 »
New question.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #10 on: Tue, 01 September 2015, 03:45:52 »
They're very quiet for a mechanical switch. Not as quiet as a mushy rubber dome, but nothing anyone would complain about I'd say.
Check my AEKII review for a typing demonstration at the end:
« Reply #11 on: Tue, 01 September 2015, 05:36:33 »
I am not sure that handwiring is suitable for harvested Alps SKCM. The clips that hold the switches to the plates weren't made to withstand switch removal so most of them will break when you harvest the switches. The switches might have to be glued in.
Offline chyros
  • a.k.a. Thomas
« Reply #12 on: Tue, 01 September 2015, 06:28:09 »
I've harvested >500 Alps switches by now (most of them SKCM Black/Late) and not had more than maybe one or two break off - how in God's name did you remove yours? xD
My Alps keychain similarly has a switch clipped into just a small frame of an AT101W mounting plate, and being in my pocket all day with ~25 other keys, it takes a lot of abuse daily. Nothing's come off and it hasn't budged in the frame yet, either.
Offline jacobolus
« Reply #13 on: Tue, 01 September 2015, 06:35:48 »
It’s not hard to desolder full keyboards without losing any little clips, or at most a couple. You just have to be careful. My recommendation is to desolder everything, then remove the PCB leaving just the switches and plate. To remove switches with greatest safety (especially helpful if the plate is thick or tight), push the clips flat against the switch housing while popping switches out of the plate.
