Author Topic: Where and how can I get a custom plate? (...questions about builder.swillkb.com)  (Read 2048 times)
Offline Vozella
Where and how can I get a custom plate for a keyboard?
http://www.keyboard-layout-editor.com/#/gists/4254aca34809c3153d9e
I tried using builder.swillkb.com to make the design.
How much different is the price of the switch types?
Is it possible I can get the switch for the spacebar in the center instead of offcentered?
Edit: Also, how much does it usually cost?
Offline trenzafeeds
  • **** off
1.You'll have to have a metal shop make it for you or if you have a fab-lab type place near you, you can probably cut it yourself.
2.Cherry brand switches are around 50 cents each, Cherry replicas are under 30 cents each usually, Alps/matias depends
3.I'm not sure what you mean, the switch for the spacebar should be in the center of your spacebar.
4.A lot
demik will never leave.
Unless he gets banned.
