Author Topic: Who the heck uses right Alt and Ctrl  (Read 35725 times)
Offline msiegel
« on: Mon, 19 October 2009, 21:28:43 »
I seem to always use the left Alt and Ctrl.
Is anyone using the right ones?
...besides Alt Gr, for Europeans... :)
Offline AndrewZorn
« Reply #1 on: Mon, 19 October 2009, 21:41:13 »
right ctrl, on normal keyboards, is for a fancy ctrl+enter or ctrl+shift+enter in web browsers
alt+enter fullscreen normally
i cant think of anything else
should probably add them to the list
scroll lock
pause/break
right ctrl
right alt
Offline msiegel
« Reply #2 on: Mon, 19 October 2009, 21:43:05 »
caps lock
just kidding, i use caps lock as ctrl ;)
Offline Rajagra
« Reply #3 on: Mon, 19 October 2009, 21:52:18 »
They are a legacy from the days when you needed to do Ctrl-Alt-Del so often, and it was convenient to do it one-handed. :lol:
But right Ctrl is handy for the arrows and Home/End, even Del. And Break.
Offline AndrewZorn
« Reply #4 on: Mon, 19 October 2009, 21:53:35 »
oh right
and ctrl-alt-del
which i havent used much since i found out about ctl+shift+esc
well, not NEAR AS much...
i just need taskman a lot
Offline msiegel
« Reply #5 on: Mon, 19 October 2009, 21:54:58 »
Quote from: Rajagra;127091
it's the vulcan nerve pinch!
well, i learned something new today :D
Offline Rajagra
« Reply #6 on: Mon, 19 October 2009, 22:00:51 »
Yes. The good old three-finger salute.
http://www.youtube.com/watch?v=1zADyh0JQh8
Offline d2v
« Reply #7 on: Mon, 19 October 2009, 22:02:31 »
I use right Alt and Ctrl all the time. For QWERTY users, the proper way (IMO, of course) to do Ctrl-x, Ctrl-c and Ctrl-v is to use right control key. I use Dvorak, but I still use right Ctrl when I have to press another key with left hand.
Right Alt is useful for Emacs' M-x (Alt-x) keystroke, even with dvorak. Also for Alt-F4.
DSI SMK-88 (Black cherry), TVS Gold, Kensington Expert Mouse, MS NEK 4000, MS NWM 6000
Offline pseudolobster
« Reply #8 on: Mon, 19 October 2009, 22:12:40 »
I use left right alt all the time for alt+left (back in most browsers), or alt+enter (fullscreen in a lot of apps)
Left Right alt is also used by all sorts of different languages, since it's technically the "altGR" key, used to compose foreign characters such as the accent keys in french and german and so forth (å,ç,ê,ï,ë, etc etc)
Now that you mention it though, I have absolutely never used the right ctrl key, nor the windows menu key (even when I have a keyboard with that key on it I end up using shift+f10, or, you know, the right mouse button)
« Last Edit: Mon, 19 October 2009, 23:03:38 by pseudolobster »
« Reply #9 on: Mon, 19 October 2009, 22:13:57 »
Quote from: d2v;127096
People still use that OS? I thought emacs died in the 70's or so...
Offline d2v
« Reply #10 on: Mon, 19 October 2009, 22:22:04 »
Quote from: pseudolobster;127099
Yes, they do.
On a side note, there exists a wiki of all text editors that ever existed, at http://texteditors.org.
« Last Edit: Mon, 19 October 2009, 22:24:41 by d2v »
Offline msiegel
« Reply #11 on: Mon, 19 October 2009, 22:39:38 »
ah, good idea :)
« Reply #12 on: Mon, 19 October 2009, 22:55:02 »
Quote from: d2v;127100
Yes, they do.
Oh, you use it as a text editor???
Oh.
Well then... Okay. Carry on I suppose.
Offline kw71
« Reply #13 on: Mon, 19 October 2009, 22:56:50 »
You should try emacs if you're not familiar with it.  Since the 'War on Drugs' it's really the only safe way to "trip" nowadays.
Offline Xuan
« Reply #14 on: Mon, 19 October 2009, 23:07:56 »
Quote from: pseudolobster;127104
Oh.
And you see it as an OS???
« Reply #15 on: Mon, 19 October 2009, 23:24:32 »
Quote from: Xuan;127106
That I say, I say that was a joke, son.
Honestly though, I see it as a bloated pile of unused and unnecessary code.. Last time I installed it I used it to play tetris for a few minutes, then went back to vi. I see it as the microsoft office of text editors.
Offline msiegel
« Reply #16 on: Mon, 19 October 2009, 23:27:18 »
Quote from: pseudolobster;127107
ok, so you won't be needing right alt and ctrl for *that*... :)
Offline d2v
« Reply #17 on: Mon, 19 October 2009, 23:33:29 »
The lack of second control key is a major frustration on keyboards with the Sun layout  (including HHKB). The Sun type 7 keyboard that I have at work, has 'Alt Graph' and 'Compose' keys in the lower right corner, below the right Shift.
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
« Reply #18 on: Mon, 19 October 2009, 23:44:48 »
Quote from: msiegel;127088
How else would you type, say, Ctrl-C? The keys are there on both sides of the keyboard so that, like the shift key, they can be used to modify keys on both sides of the keyboard after the fashion of normal touch-typing.
It's true that the Alt key isn't used much, unless one is using an application with keyboard shortcuts.
Offline msiegel
« Reply #19 on: Tue, 20 October 2009, 00:02:36 »
Quote from: quadibloc;127112
I'm on the Mac, and I use left Alt as Command. Caps Lock functions as Ctrl, and Win is used as Option.
I don't use the normal Ctrl keys, nor the right Alt, Windows, or Menu keys :)
Offline kode
« Reply #20 on: Tue, 20 October 2009, 02:16:44 »
Must say I liked that screencap. The guy who put it up on the lysator web server has a .emacs and a .emacs.d in his home directory, so I'm pretty sure he uses emacs. :)
vi is bloat. ed is where it's at.
Offline ironcoder
« Reply #21 on: Tue, 20 October 2009, 03:10:55 »
Yes, I use right alt as an escape for VirtualBox. It works great for that since it's useless for anything else. Right ctrl, never. I usually remap some/all of the useless keys including the winbloze keys if the board has them, since I need extra keys for IBM terminal emulation.
In the office: Filco 87 Cherry Browns x 2 (one with coffee damage, recovered) ● Lexmark IBM Model M 52G9658 1993 & 1996
Offline ironcoder
« Reply #22 on: Tue, 20 October 2009, 03:12:14 »
That's a joke, because Emacs is so huge and has so many zillions of features that have nothing to do with editing because it was written in a special dialect of Lisp that lets you customize it without end. They say Emacs is a horrible OS with a good editor, something like that.
Offline ironcoder
« Reply #23 on: Tue, 20 October 2009, 03:12:54 »
Yes it died in the 1970s and yes we still use it.
Offline ironcoder
« Reply #24 on: Tue, 20 October 2009, 03:16:47 »
Clearly you are a young guy who has never learned to player twister (do you know what that is?) on the keyboard.
Ctrl-C is properly executed by putting your left thumb on ctrl, your left index finger on left shift and hitting c with your right index finger. Right shift, right alt, and right ctrl are strictly passe.
The main idea is to always use the left hand for alt, ctrl, and shift and the right hand for any other characters used in combination with those 3.
Offline DreymaR
  • Colemak forum guy
    • DreymaR's Big Bag of Kbd Tricks
« Reply #25 on: Tue, 20 October 2009, 04:11:16 »
The right-hand Ctrl key is used for one-handed Ctrl+PgUp/Dn, Ctrl-arrows and suchlike. Useful for some of my programs.
Better burden you cannot carry than man-wisdom much ~ Hávamál
Offline Rajagra
« Reply #26 on: Tue, 20 October 2009, 11:39:36 »
True, but how often have you heard people criticize Dvorak because the layout goes against their muscle memory for keyboard shortcuts? There are clearly a vast number of people doing Ctrl-X/C/V using just their left hand. And they consider it to be the right way.
Offline d2v
« Reply #27 on: Tue, 20 October 2009, 11:46:50 »
Quote from: Rajagra;127187
When I started using dvorak, it took me a total of two weeks to get used to new positions of X, C and V. All it takes is consistently following the correct Control key usage (left or right). Some typing lessons also help in memorizing new letter positions.
Another way to do it is to use Ctrl-Insert for copy, Shift-Insert for paste, and Shift-Delete for cut. These are legacy shortcuts from DOS era, and are independent of the layout (so long as modifiers don't move)
Offline msiegel
« Reply #28 on: Tue, 20 October 2009, 11:47:24 »
yep, left hand is the right way ;)
uh-oh, i'm a caps lock control swapper
Offline FourOhFour
« Reply #29 on: Tue, 20 October 2009, 11:56:20 »
Quote from: ripster;127189
Blog and comments here.
I personally just use my left hand for modifiers including SHIFT just because it involves less pinky stretching.
Same. And judging from the wear patterns on this model m, same with it's previous owners. Right shift looks untouched, while all the left modifiers have a little shine to them. Even caps lock.
I'll occasionally use right command (alt) for cmd-L, [, and ] (focus address bar, back, and forward), and right shift for shift-pageup/down.
Offline itlnstln
« Reply #30 on: Tue, 20 October 2009, 12:09:45 »
I use my left pinky for all modifiers myself.  I guess I really never noticed why, but as ripster said, the left pinky has to do less stretching to get to those positions, so I think, subconciously, I ended up using my left pinky exclusively.  I never really use the right Ctrl and Alt for anything more than the three finger salute.
Offline d2v
« Reply #31 on: Tue, 20 October 2009, 12:11:43 »
Xah Lee has been posting on the Emacs mailing lists for years. He is also pushing for Common User Access (CUA) controls (Ctrl-X, C, V) to be default.
I was using caps lock as ctrl until I read his article.
Yes, the pinky has to do all the heavy lifting in pressing the modifier keys, resulting in sore pinky problem. (Emacs is famous for this, and this issue frequently comes up in Emacs vs. Vi flamewars. )
I suppose the humble hacker keyboard layout gets it right. It puts the modifier keys between left and right hand keys, to be actuated by index finger.
Offline itlnstln
« Reply #32 on: Tue, 20 October 2009, 12:17:05 »
Quote from: d2v;127196
I think the uTron keyboard does the same thing.
Offline ironcoder
« Reply #33 on: Tue, 20 October 2009, 12:17:48 »
I learned that way too. I use the left thumb for alt or ctrl and another left finger for most keys west of L or O. East of that is right hand land.
The pinky never gets used, I don't think.
Offline itlnstln
« Reply #34 on: Tue, 20 October 2009, 12:20:12 »
If you use your left thumb for Ctrl duties, I can see why you might not like having Windows keys.  Win keys put Ctrl in the perfect spot for pinky use.
Offline ironcoder
« Reply #35 on: Tue, 20 October 2009, 12:27:09 »
I don't get it, on all the keyboards I have ctrl is always the leftmost key. Did you mean alt?
My objection to winbloze keys is purely MS hatred and the fact that they have no function since I don't use bloze. If I have them they just get in the way, but I think I use every keyboard more or less the same way. I expect ctrl and then alt somewhere east of that.
« Last Edit: Tue, 20 October 2009, 12:30:13 by ironcoder »
Offline ch_123
« Reply #36 on: Tue, 20 October 2009, 12:38:27 »
Alt Gr is useful. Could live without right control though.
Offline itlnstln
« Reply #37 on: Tue, 20 October 2009, 12:40:57 »
Quote from: ironcoder;127202
Nevermind.  I was thinking that Ctrl was right next to Alt on the older 'boards.
Offline ironcoder
« Reply #38 on: Tue, 20 October 2009, 13:34:43 »
Yes it probably is. The winbloze key is usually right between them on new boards.
I can't remember because alt and ctrl don't compute for IBM keyboards, but when I use NIX I use them.
Offline urlwolf
« Reply #39 on: Tue, 20 October 2009, 13:48:32 »
The proper way to do Ctrl-x, Ctrl-c and Ctrl-v is to use right control key. In general, all chords are better done with two hands. I was surprised by this too. I read it on the kinesis manual, they say that one-handed shortcuts are dangerous, and I believe it now (a reference wouldn't hurt; if anyone finds  one, please post).
I have hundreds of autohotkey shortcuts that a did single-handed. needless to say, I got pain, and worried about being able to type long stretches anymore. Fortunately, after using the kinesis contour AND good chording on any other keyboard, no pain to speak of. Be careful out there :)
keyboards: Cherry G80-3494- cherry reds | filco majestytouch - cherry browns | kinesis contour - cherry browns | cherry G80 - 1800 cherry blacks.
mice: filco touchpad | logitech G9x | wowpen joy | kensington orbit trackball | zalman fpsgun | intellimouse v1 | logitech rx1500
Offline Rajagra
« Reply #40 on: Tue, 20 October 2009, 13:48:51 »
The idea of using the palm of your hand to hit Ctrl is unintuitive, but brilliant. I must remind myself to try doing it. The joint at the base of my pinkie is in just the right place.
It would be worth having extra height on the Ctrl key to make it even easier.
Offline ironcoder
« Reply #41 on: Tue, 20 October 2009, 13:55:15 »
Quote from: ch_123;127209
Ok, what is Gr?
Offline itlnstln
« Reply #42 on: Tue, 20 October 2009, 14:04:27 »
Quote from: ironcoder;127231
Ok, what is Gr?
IIRC, AltGr is used on German layouts as a modifier to type alternate forms of letters used in the language.
Offline ironcoder
« Reply #43 on: Tue, 20 October 2009, 14:24:17 »
Thanks no wonder I never heard of it!
Offline Rajagra
« Reply #44 on: Tue, 20 October 2009, 14:28:54 »
Quote from: itlnstln;127236
I think you'll find that vanilla US layout is about the only one that doesn't use it.
Offline texteur
« Reply #45 on: Tue, 20 October 2009, 14:29:39 »
Exactly the same on Swiss French keyboards (very close to German ones).
IBM Model M Space Saver, 1391472, PS/2, US layout, year 1987 | Apple Standard Keyboard, M0118, ADB, Swiss French layout, year 1987 | IBM Model M, 1391401, PS/2, US layout, year 1988 | IBM Model M Space Saver, 1392934, PS/2, US layout, year 1988 | IBM Model M, 1391403, PS/2, German layout, year 1988 | IBM Model M, 1391403, PS/2, German layout, year 1991 | Apple Extended Keyboard II, M3501, ADB, ANSI layout, year 1995 | DSI Switch Mac Keyboard, SMK-88SMK88-EM/JM, Black Cherry Switches, USB 1.1 & 2.0, ANSI layout, year 2006 | Happy Hacking Keyboard Professional 2, white with blank keycaps, PD-KB400WN, Topre 45g switches, USB, UNIX key layout, year 2007 | Das Keyboard Ultimate, DASK3, USB, European layout, year 2008 | Topre Realforce 86U, SE0500, USB, ANSI layout, ergonomically weighted switches, year 2009 | Topre Realforce 87UB, SE1700, USB, ANSI layout, ergonomically weighted switches, year 2009 | Filco Majestouch "Otaku", FKBN104MC/NPEK, Blue Cherry MX switches, USB, ANSI layout, year 2009 | Filco Majestouch Tenkeyless Tactile Touch, FKBN87M/EB, Brown Cherry MX Switches, USB, 87 Key ANSI layout, year 2009 | Filco Majestouch Ten Key Extended Keypad, FKB22MB, Brown Cherry MX Switches, USB, year 2009
[/SIZE][/FONT][/COLOR]
Offline AndrewZorn
« Reply #46 on: Tue, 20 October 2009, 14:32:59 »
çółémák ȟä§ ít
Offline lowpoly
« Reply #47 on: Tue, 20 October 2009, 14:42:45 »
Quote from: urlwolf;127226
When in Photoshop I use my left hand for Ctrl combinations. Ctrl on
CapsLock is much easier to reach then, especially for Ctrl-X. And Ctrl-Z with the palm on the lower left Ctrl - no thanks.
I use my palm on the lower left Ctrl when I Ctrl-click with the Trackpoint.
Ok, what is Gr?
Gr is for Graphics: http://en.wikipedia.org/wiki/Altgr
Offline Hakhu
« Reply #48 on: Tue, 20 October 2009, 15:49:23 »
Quote from: ironcoder;127130
Yeah, almost. They (tm) say: "it's a great OS without any good text editor."
But yeah, the reasoning for this is right.
Anyway, we still use emacs at work. And it's still great, as an editor, for version control, to compile. One of my collegues uses it to read mail and as a web browser.
So yeah ... it's almost an OS. ;)
There was a guy once that used emacs to control his coffee machine.
Offline Hakhu
« Reply #49 on: Tue, 20 October 2009, 15:51:52 »
Almost forgot:
I use left ALT as Meta for emacs. Don't really need ALT. And the right CTRL as Multi-Key to write German Umlaute, like ü, ö and ä, if I have to write a mail in German.
