Author Topic: PS/2 -> USB adapters with reasonable logic  (Read 1317 times)
Offline lsh
  • Achievement unlocked: Keyboard older than wife
    • lsh.io
« on: Wed, 09 September 2015, 18:47:36 »
Today, I wrote a little script to blink my Scroll Lock light if I have an incoming message that I'd consider critical.
Today, I learned that the cheapass PS/2->USB converters I bought at the salvage shop for $1 each completely reset the keyboard state (i.e. send a break for every key) when the state of an LED changes.
Does anyone know of a brand/model of adapter that doesn't do this? Are Soarer's adapters okay with this? I'm sure I could get a teensy and fix the logic if need be, but I'm impatient and would rather just buy something.
(quick test if you're curious and running linux: open a terminal and run the command:
while true; do xset led 3; sleep 0.5; xset -led 3; sleep 0.5; done
Then try typing, performing chords, etc. Kill the terminal to stop the madness.)
Thanks folks!
Offline jerue
  • (Whenever that happens :P)
Re: PS/2 -> USB adapters with reasonable logic
« Reply #1 on: Wed, 09 September 2015, 19:51:51 »
Interesting. Your keyboard probably is requiring too much power, do you know if you have an active PS/2 adapter?
You'd probably want something like this: Monoprice PS/2 Adapter. I have had no trouble with my IBM keyboards using this adapter. Soarer's would definitely work although they are a bit more expensive.
