Author Topic: Blank, transparent keycaps  (Read 7457 times)
Offline polipoli
« on: Fri, 11 September 2015, 03:12:18 »
Hi, I'm using a ducky shine 4, and i would like to know if there are any obtainable blank transparent keycaps that can fit my keyboard. so i'll have both cool lights and blank keycaps for elite typing :P
Offline LechnerDE
Offline polipoli
Re: Blank, transparent keycaps
« Reply #2 on: Fri, 11 September 2015, 03:54:25 »
Looks good, are those compatible with Ducky shine 4?
Offline LechnerDE
« Reply #3 on: Fri, 11 September 2015, 03:58:15 »
If you have an ANSI board then yes. But keep in mind that you only get 104 keys. If I am not mistaken the Ducky has 4 extra keys above the numpad.
Maybe you could ask Signiture Plastics if you could buy 4x Row 1 singles.
Offline polipoli
« Reply #4 on: Fri, 11 September 2015, 04:06:57 »
The 4 additional ones the ducky has are for Calc, PC, Mail and Browser homepage. It'd make sense to just leave them be, but in case i want to replace those too, it shouldn't be a problem.
Offline seville57
« Reply #5 on: Fri, 11 September 2015, 07:31:05 »
I have tested this 104 keys set on a ANSI Ducky Shine 3 Cherry MX Black k-board. So it will fit on a ANSI Ducky Shine 4, Duckys own keycaps sets will fit on Shine 2, 3 and 4. I don't have a Shine 1 k-board just some Shine 2, 3 and 4 k-boards.
The up,down, left and right arrows (Qwerkeys), blue + the 4 (Qwerkeys) over numpad caps don't belong to the set from SP. The blue caps are from SP:s transparent blue 13 keys kit.
My Ducky Shine 4 SCE Cherry MX Brown/Clears bought on Massdrop.
The Brown/Clear switches.
My Ducky Shine 4 69 Edition Fire Version (the switchtester) with 9 different switches and Galaxy Class keycaps set from Massdrop. The spacebar is Duckys 69 own.
Ducky Shine 4 69 original keycaps set.
Edit: Don't know about the link LechnerDE linked keycaps design but some of mine keycaps are not standard keycaps design.
I bought mine sets last year.
« Last Edit: Fri, 11 September 2015, 13:47:10 by seville57 »
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #6 on: Fri, 11 September 2015, 14:43:47 »
I have the MAX Keyboard blank black transparent set if you wanna buy them.
Sold my K70 so I have no use for them now.
They look like blank blacks until you light them up & should work on the shine 4 since there's extra keycaps for multiple layouts.
Long exposure shot here so the won't actually get that bright.
Offline seville57
« Reply #7 on: Fri, 11 September 2015, 15:32:58 »
I also have this ANSI/English ISO (front printed) set and had used the set on a ANSI Ducky Shine 3 board, so it will fit on a Ducky Shine 4 board. As you say there are extra caps.
Lookin good on your picture.
http://www.maxkeyboard.com/max-universal-cherry-mx-translucent-clear-black-full-keycap-set-front-side-print.html
http://www.maxkeyboard.com/mechanical-keycap-layout-and-size-chart.html
« Last Edit: Fri, 11 September 2015, 15:54:06 by seville57 »
