Author Topic: BenQ xl2411z issue.  (Read 2280 times)
Offline foxer
  • Formerly wadeu
BenQ xl2411z issue.
« on: Fri, 11 September 2015, 18:53:17 »
So, I've just got this monitor today. Absolutely love the look of it and performs brilliant. However, just had this issue. Then gone back to normal.
I was playing a custom on dota then all of a sudden the screen like had a grey layer over it with criss cross patterns everywhere. I think it happens every 30 minutes or so as it's happened again so plugged old monitor back in.
Can't really tell in pictures but it was much more clear in person.
http://i.imgur.com/4kbkL7i.jpg [1]
http://i.imgur.com/SG4FRJI.jpg [2]
Any help is much appreciated.
Unbowed, Unbent, Unbroken.
Offline foxer
  • Formerly wadeu
Re: BenQ xl2411z issue.
« Reply #1 on: Fri, 11 September 2015, 19:10:17 »
What pictures currently look like...
http://i.imgur.com/cp86t8c.jpg
Offline osi
« Reply #2 on: Tue, 15 September 2015, 07:27:43 »
Maybe a loose cable connection? Also try using an alternate cable or DisplayPort if you've got it.
