Author Topic: Custom keyboard plate CAD scaling?  (Read 1687 times)
Offline SeanTNT
« on: Tue, 15 September 2015, 22:58:17 »
Hello ,
 I am currently trying to build a custom keyboard but I still have some questions about the plate and the mid filler parts. In particular the scale I took some resources from GH CAD Resources  linked here; https://geekhack.org/index.php?topic=47744.0 . I wanted to know if the scaling were right since I don't fully understand how CAD works. I would also like to get a second opinion about the screws holes since I will be using M2x5 but with spacers in between I don't know if the holes should be 2mm based on the screws thread or bigger. Any input relavent to the projent would be much appreciated[/font]
Offline SeanTNT
Re: Custom keyboard plate CAD scaling?
« Reply #1 on: Tue, 15 September 2015, 23:00:52 »
Ah yes I forgot that the screws I will be using is linked here:http://ortholinearkeyboards.com/keyboard-parts/assembly-kit
