Author Topic: Winkeyless 60% cases  (Read 4752 times)
Offline trenzafeeds
  • **** off
« on: Thu, 17 September 2015, 16:17:43 »
Is that a thing or not. I'm not talking about hhkb-style winkeyless, but rather missing winkey like this:
demik will never leave.
Unless he gets banned.
Offline Hzza
Re: Winkeyless 60% cases
« Reply #1 on: Thu, 17 September 2015, 16:21:39 »
Not a winkeyless case per se, but similar to the above.
https://geekhack.org/index.php?topic=39702.msg782343#msg782343
Offline trenzafeeds
  • **** off
« Reply #2 on: Thu, 17 September 2015, 16:25:18 »
What did you do?
Offline Hzza
« Reply #3 on: Thu, 17 September 2015, 16:26:28 »
It's not mine but the details are in the link ;). Couple of bits of plastic on top of switches without stems more or less.
Offline KHAANNN
« Reply #4 on: Thu, 17 September 2015, 16:27:52 »
It seems to have a spacer
Don't know about the case, but you could just get a winkeyless plate and get 99% there, it would look like the keyboard Hzza shared
You can get a silver case for example, maybe a TEX, and a stainless steel plate made, it would pretty much look winkeyless with a small bit of gap
« Reply #5 on: Thu, 17 September 2015, 16:34:31 »
Most 60% cases are tray style cases, as it makes the most sense for the form factor. There are some that aren't e.g 356mini, but most are trays..
To have winkey blockers in a tray style case you would require the PCB to have cutouts where the winkeys are, otherwise it would not be possible. Since no PCBs are like this it's rare for 60% cases to have winkey blockers.
If you look at the duck viper you will see what I mean. It has blockers at the ends and it's a tray style case. The PCB has cutouts to allow it.
Offline kampongkid
« Reply #6 on: Thu, 17 September 2015, 17:09:59 »
Ive seen a KMAC Happy with 1u blockers added to achieve this. Not sure on the PCB cutouts mentioned above.
Offline ika
« Reply #7 on: Thu, 17 September 2015, 17:29:55 »
Are tray-style cases a uniform height? You can use the Cherry blockers that Signature Plastics sells to get a similar effect, although I don't know what the tolerances are or if there will be gaps etc. I doubt it will look as clean and nice as Hzza's link, though.
