Author Topic: Desoldering plate-mounts without a pump  (Read 4732 times)
Offline trenzafeeds
  • **** off
« on: Thu, 17 September 2015, 18:55:43 »
I need to desolder some plate-mount switches. I'm currently out of working pumps. No, I haven't got any spare copper wire to wick with, before you suggest it. Anyone have any other methods?
demik will never leave.
Unless he gets banned.
Offline FrostyToast
  • Litshoard
Re: Desoldering plate-mounts without a pump
« Reply #1 on: Thu, 17 September 2015, 19:12:39 »
Well if you want you can heat up both joints while simultaneously prying out the switch.
However, you should not do this unless the PCB you are working with is disposable. Leaving solder on the pcb is dumb and it can also flow to places you don't want it to.
Quote from: elton5354
Offline ika
« Reply #2 on: Thu, 17 September 2015, 19:13:55 »
Might be a long shot but if you're into photography, those air blower things (like this) can be used as solder suckers in a pinch. Otherwise I'd say to just get one on Amazon with Prime or something.
Offline FrostyToast
  • Litshoard
« Reply #3 on: Thu, 17 September 2015, 19:15:47 »
This. No one needs to desolder switches so badly they can't wait a couple days.
Offline trenzafeeds
  • **** off
« Reply #4 on: Thu, 17 September 2015, 19:19:54 »
They're plate mount
There are already some coming, I was just bored. Thanks for the responses anyway!
Offline radish
« Reply #5 on: Thu, 17 September 2015, 23:37:21 »
Absolutely agree here. The head ache you save yourself I can't even describe. It will be the Best 5$ you'll spend on wick. Maybe rosin to but yea... Don't rush it and try to do it with out the proper tools. I wouldn't anyhow. Best of luck.
LZ CP
Offline burn1nsun
    • My stupid YouTube Channel
« Reply #6 on: Sat, 19 September 2015, 10:43:17 »
I tried this, its very hard and annoying compared to doing that with a pump. Thanks to this my caps lock doesnt work right now too. Because it had leds and it was hard to desolder. I didn't desolder it though.
HHKB Pro 2 l Pok3r Gateron Blacks
Offline bazemk1979
« Reply #7 on: Mon, 21 September 2015, 19:20:23 »
always use pump, I think radioshack sells them for $15 on ebay, also don't forget to get few spare tips if you need to desolder a whole board
Offline FrostyToast
  • Litshoard
« Reply #8 on: Mon, 21 September 2015, 19:24:00 »
They're plate mount
Well for that trick the mounting is no real issue.
It's slightly harder with plate mount but all you need to do is pry out the switch with a screwdriver from the underside.
Offline trenzafeeds
  • **** off
« Reply #9 on: Mon, 21 September 2015, 19:30:20 »
They're plate mount
Ouch, not sure I'd attempt that. It's fine though, my solder pump has arrived in the mail.
