Author Topic: Can you identify this switch?  (Read 2046 times)
Offline Tuntematon
« on: Thu, 17 September 2015, 19:38:45 »
I'm not familiar with this and a quick search didn't turn up an answer. Do you know what it is?
Offline BADBADNOTGOOD
Re: Can you identify this switch?
« Reply #1 on: Thu, 17 September 2015, 19:53:28 »
Something foam and foil.  idk the manufacturer though.
« Reply #2 on: Thu, 17 September 2015, 19:54:50 »
« Last Edit: Fri, 18 September 2015, 01:07:34 by demik »
Offline Tuntematon
« Reply #3 on: Thu, 17 September 2015, 20:13:18 »
Thanks, foam and foil looks to be correct. The keyboard is a Chicony 5391, which I can't find any info on, and I can't find the switch manufacturer either. It's a bit of a mystery board I guess.
Offline Altis
« Reply #4 on: Thu, 17 September 2015, 21:33:58 »
What's it like to type on?
Offline Tuntematon
« Reply #5 on: Thu, 17 September 2015, 22:12:29 »
That remains to be seen, I just bought it today on eBay.
