Author Topic: How can I find out the measurements of my custom plate design?  (Read 1978 times)
Offline Vozella
« on: Thu, 17 September 2015, 21:32:47 »
I want to get a quote from bigbluesaw.com, but I don't know the measurements of my custom plate.
111290-0
Re: How can I find out the measurements of my custom plate design?
« Reply #1 on: Thu, 17 September 2015, 22:26:36 »
If you made the plate using swill's plate builder,  the dimensions are in mm.
Offline Vozella
« Reply #2 on: Mon, 21 September 2015, 16:06:10 »
The picture I provide is from his website. I don't see the measurements anywhere. Do I have to download the files and open them up in the program to see?
« Reply #3 on: Mon, 21 September 2015, 16:12:45 »
Yes, if you plan on using BigBlueSaw, I believe they require the DXF file. It will have dimensions, but no units. The units are millimeters.
