Author Topic: CM storm novatouch tkl custom controller  (Read 2634 times)
Offline themagicat
« on: Fri, 18 September 2015, 20:26:56 »
I was wondering if it was possible... easy... to put a custom controller into a novatouch tkl. Would a frosty flake work?
Re: CM storm novatouch tkl custom controller
« Reply #1 on: Fri, 18 September 2015, 20:29:16 »
Not easy the internals are topre capacitive parts. And no the frosty flake won't work.
I'm not sure if hasu's USB to USB converter would work or not, you might look into that.
« Last Edit: Fri, 18 September 2015, 20:32:29 by SpAmRaY »
« Reply #2 on: Fri, 18 September 2015, 23:06:36 »
Yeah, in theory it would work perfectly, just not as neat as a custom controller.
