Author Topic: Help! Unable to desolder Pok3r  (Read 3872 times)
Offline trenzafeeds
  • **** off
« on: Tue, 22 September 2015, 20:53:24 »
Currently trying to desolder a Pok3r, but I'm having a problem getting all the solder off the switches. The pump I'm using seems pretty good, so the only thing I can think of is that maybe my iron isn't hot enough to get to all the solder melted. I'm using exactly the suggested technique form instructional videos, but for some reason a small amount of solder always remains in the holes no matter how much I try to suck it out. Does anyone have any ideas as to what I can do to fix this?
demik will never leave.
Unless he gets banned.
Offline digi
  • elite af tbh
  • keyboard game on fleek
Re: Help! Unable to desolder Pok3r
« Reply #1 on: Tue, 22 September 2015, 21:31:20 »
It sounds like your temp isn't high enough if you're confident that your Soldapult is working correctly..
I usually turn my iron up 50 degrees (F) when I de-solder, also goes faster. How long does it take for the solder to melt when you hold the tip to the solder/pad?
Offline neverused
« Reply #2 on: Tue, 22 September 2015, 21:36:00 »
I'm not sure which videos you have watched but I suggest looking up the eevblog on YouTube, he's great. Also, try adding new solder to the joint before you desolder it.
Offline blcksqrrl
  • I'm afraid that I just blue myself
« Reply #3 on: Tue, 22 September 2015, 21:36:53 »
It may sound counterintuitive, but adding a small amount of solder back to the joint may help you get it desoldered.
Agreed. Should've read that newport.
Poker II MX Blue
KUL ES-87 MX Blue
Apple Standard Keyboard
Apple Extended Keyboard II
Offline trenzafeeds
  • **** off
« Reply #4 on: Tue, 22 September 2015, 21:43:49 »
Yes I know to do that, some of it's coming out just not all of it.
Offline digi
  • elite af tbh
« Reply #5 on: Tue, 22 September 2015, 21:44:32 »
If you're having the problem on a lot of contacts then something else isn't right, in my experience I typically almost never have to add solder if my Soldapult and temps are right.
If you have to add solder on 2-3 pads, that's reasonable but not on every contact.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #6 on: Wed, 23 September 2015, 05:09:01 »
You might have to clean the internals of your soldapullt.
Overtime, the solder accumulates inside and the "sucking" power of it isn't that strong anymore.
You can try by pressing the plunger down and using your thumb or finger to block the tip.
If you release it and the plunge moves, it means there's a lot of stuff accumulated inside.
No harm trying though.  :)
Offline bcredbottle
« Reply #7 on: Wed, 23 September 2015, 12:28:50 »
I had the exact same problem with my Ergodox. This video solved it for me..
Also,
(A) keep your tip tinned
(B) always put a tiny drop of solder on the tip of your iron before putting the tip to the soldered joint (it helps the tip melt all of the existing solder better)
(C) make sure you've got suction. I had to switch from one of those crappy little $6 solder suckers to a soldapult, which has more than enough suction power.
Offline trenzafeeds
  • **** off
« Reply #8 on: Wed, 23 September 2015, 16:28:47 »
Also,
Unfortunately I don't think the tip of this iron is ever going to be tinned again, but I'll definitely give this video a try, thanks a ton!
Offline bcredbottle
« Reply #9 on: Wed, 23 September 2015, 16:35:09 »
Oh and frequently wipe off the tip on a wet sponge. Most of the time you don't even need tinner.
Offline trenzafeeds
  • **** off
« Reply #10 on: Wed, 23 September 2015, 16:41:17 »
I do my best... this one might be beyond repair though. Still tends to work okay luckily. I've never had a problem until now, and it hasn't gotten dramatically worse recently.
