Author Topic: What LED colors does the Pok3r PCB support?  (Read 1633 times)
Offline KaminKevCrew
« on: Thu, 24 September 2015, 01:22:24 »
According to this thread: https://geekhack.org/index.php?topic=71030.0 Non-LED pok3r boards support LEDs as long as your'e willing to solder them on yourself. I would really like to put some pink LEDs in the Pok3r that I have in the mail, but does anyone know if I will have to replace components on the board to support pink, or should I be fine?
Re: What LED colors does the Pok3r PCB support?
« Reply #1 on: Fri, 25 September 2015, 11:16:56 »
The resistors can change the warmth of the pink but stock ones will work.
« Reply #2 on: Fri, 25 September 2015, 13:58:08 »
Awesome! Thanks man!
Offline merlin64
    • MechMerlin
« Reply #3 on: Fri, 25 September 2015, 13:59:40 »
What are the characteristics of the stock ones?
