Author Topic: [GB] Alpine Winter (Shipping Replacements)  (Read 2807657 times)
Offline njbair
    • nickbair.net
Re: [GB] Alpine Winter - 60% Alps DCS Keycaps
« Reply #50 on: Sat, 26 September 2015, 11:12:24 »
Wow, great response so far, everyone!
If you are on Reddit, please take a minute to upboat this post and help get the word out: https://redd.it/3mc2d7
My boards:
Offline njbair
    • nickbair.net
« Reply #51 on: Sat, 26 September 2015, 14:02:28 »
A couple of fun updates to share...
Alpine Winter is featured on KeyChatter! Thanks, livingspeedbump! Check it out.
Major milestone update: We have met or exceeded the 50% mark for all three MOQs! That means that in less than two days' time, we're already halfway there. We are also well past the halfway marks for all three spacebar add-on packs (60-80%), and the novelty pack has blown past MOQ at 144%.
Response for add-on blanks has been solid. I have added totals tracking for blanks to the status page. I have to enter these manually, so don't expect to see new orders right away.
My boards:
Offline BlueNalgene
« Reply #52 on: Sat, 26 September 2015, 17:25:19 »
Oh sure, your GB gets mentioned but mine doesn't.   >:D
Just kidding.  I'm already way post my MOQ and yours still needs a little love.   :p
But in all seriousness, if your GB doesn't pass I'm going to start cracking skulls.
Offline njbair
    • nickbair.net
« Reply #53 on: Sat, 26 September 2015, 17:28:52 »
I'm zero worried at this point, so far signups have been waaaay higher than I expected, and I've got a longer deadline than your buy.
My boards:
Offline BlueNalgene
« Reply #54 on: Sat, 26 September 2015, 18:38:57 »
I'm just razzing.  You have great stuff  here and I'm confident in it.
Offline Mililala
« Reply #55 on: Sat, 26 September 2015, 18:40:47 »
I have a little question about blanks.
All combinations of these colors sizes and rows has individual MOQ?
Offline njbair
    • nickbair.net
« Reply #56 on: Sat, 26 September 2015, 18:42:39 »
Yes, 25 each. But I'm going to try really hard to see that they get made.
My boards:
Offline Spaceman1200
« Reply #57 on: Sun, 27 September 2015, 08:01:08 »
Could you do me a favor and make sure i added a novelty pack and a aek2 bar to my order?
Offline njbair
    • nickbair.net
« Reply #58 on: Sun, 27 September 2015, 08:22:41 »
Yep, I have you down for both.
My boards:
« Reply #59 on: Sun, 27 September 2015, 08:25:17 »
Sweet! Thanks.
Offline njbair
    • nickbair.net
« Reply #60 on: Sun, 27 September 2015, 16:41:52 »
Guys, I'm super-excited to show off a pair of really awesome 3D renders from new Geekhack member thesiscamper:
You may have seen some of thesiscamper's work in his Joker/Eva IC thread. As soon as I saw his keyboard renders I knew I had to have some for Alpine Winter!
Be sure to view these renders full-size and check out the extreme detail. And if you need any 3D work done, I highly recommend him. He's friendly and courteous, and his prices are very fair.
My boards:
Offline ideus
  • Björkö.
« Reply #61 on: Sun, 27 September 2015, 16:45:27 »
More real than the real thing.
Offline Hypersphere
« Reply #62 on: Sun, 27 September 2015, 17:01:07 »
Those renders look great! I am definitely buying at least one set -- but I need to wait until October.
Offline sean
  • Mechanical newb
« Reply #63 on: Sun, 27 September 2015, 21:28:59 »
It looks so real I can almost touch them...
Offline njbair
    • nickbair.net
« Reply #64 on: Sun, 27 September 2015, 21:38:31 »
I know! I'm getting antsy now.
My boards:
Offline E3E
« Reply #65 on: Sun, 27 September 2015, 21:49:00 »
Ahh those renders are too tasty!
Offline Muffinbottoms
« Reply #66 on: Mon, 28 September 2015, 03:41:10 »
Phew! Finally got my order in! Those renders are making me giddier than a school girl!  ;D
Offline sth
  • 2 girls 1 cuprubber
« Reply #67 on: Mon, 28 September 2015, 03:43:54 »
How thick are these? I'd be interested in them for casting purposes...
It's Signature Plastics DCS, so not very thick.
7-bit keeps threatening an SA-like Alps keycap buy. So watch for that in the 2020s!
Talk is cheap, especially coming from 7-bit..lol
7bit is slow but he releases :)
Offline ideus
  • Björkö.
« Reply #68 on: Mon, 28 September 2015, 07:48:40 »
I do not get the image. Do you have an animated gif to get it?
Offline Hypersphere
« Reply #69 on: Mon, 28 September 2015, 08:27:52 »
@njbair: Which Alps mount will SP use as the standard for molding the keycap stems to fit Alps-mount switches? The reason I ask is that I ran into some issues fitting caps from some vintage boards into mounts on Matias switches. The caps would appear to fit, but in some cases the stem was slightly too large for the mount, which apparently caused enough expansion to cause the switch to bind.
Offline njbair
    • nickbair.net
« Reply #70 on: Mon, 28 September 2015, 08:55:57 »
SP is not making any new tooling for this set, so fitment should be the same as their existing Alps caps. I have some DSA Alps PBTs from an Infinity kit and they are tight in Matias switches, but DSA are always tight since they were designed for industrial applications.
I've got Badwrench's mods coming in the mail this week, so I'll be able to try out DCS Alps caps on Matias switches. I'll get back to you then.
My boards:
Offline njbair
    • nickbair.net
« Reply #71 on: Mon, 28 September 2015, 11:26:06 »
I forgot, I actually bought an Alps keyboard from the classifieds last week, and it came with a DCS "GEEK HACK" keycap. It arrived this morning, and I was able to check the fitment with a Matias switch on my Infinity keyboard. I'd say it's just right; not to loose, not too tight.
Alps caps are a bit harder to remove in general versus MX. I find the best way to get them off is to rock them side to side while applying slight upward force. Using a long-handled key puller, this motion looks like moving from left to right over and over again on an Atari joystick, if that helps illustrate what I mean.
My boards:
« Reply #72 on: Mon, 28 September 2015, 12:33:02 »
Side to side rocking is a good way to break the cap stem.  It's harder, but a straight pull is what I recommend.  Only rock if you have to.
Offline Badwrench
  • ummmm.....I forgot
« Reply #73 on: Mon, 28 September 2015, 14:04:41 »
My recommendation is to take a spare switch or old board and mount each cap once.  It removes any flashing.  I found that after being mounted once and removed, the caps were much easier to mount and remove.
Offline njbair
    • nickbair.net
« Reply #74 on: Mon, 28 September 2015, 17:47:18 »
Listen to this guy not me.
My boards:
Offline sean
  • Mechanical newb
« Reply #75 on: Mon, 28 September 2015, 18:12:50 »
Too late, keyboard on fire.
Offline nathanrosspowell
    • nathanrosspowell.com
« Reply #76 on: Mon, 28 September 2015, 21:50:16 »
Gah. I am meant to be saving for a new PC rig but seeing as I already have an Infinity kit... in @ 50 MOQ.
Offline cheddarbek
« Reply #77 on: Mon, 28 September 2015, 23:43:35 »
Just joined for a set + some sadsters.
The Alps cover 65% of Switzerland's surface area (41,285 km²), making it one of the most alpine countries. Despite the fact that Switzerland covers only 14% of the Alps total area (192,753 km²),[2][3] many alpine four-thousanders (48 of 82) are located in the Swiss Alps and practically all of the remaining few are within 20 km of the country's border.
Offline trees
  • I like bagels.
« Reply #78 on: Tue, 29 September 2015, 11:01:48 »
In for this and the Alps Party 60% as my first ever GB  ;D
B.Face HHKB - B.mini - Black/Purple Custom
Offline njbair
    • nickbair.net
« Reply #79 on: Tue, 29 September 2015, 17:09:34 »
Orders have slowed down a bit after the weekend (as was expected), but we are looking good for 5 days into the buy. Were 84% of the way to 50 sets, and 66% of the way to 100!
The interest in ala carte blanks has been a little lower than I had expected...We've still got a long while until the buy closes on October 24, so hopefully the orders for blanks pick up so that everybody can get what they want. I'm working with Signature Plastics to figure out the best way to make that happen.
My boards:
Offline cheddarbek
« Reply #80 on: Tue, 29 September 2015, 17:12:00 »
I'm thinking the blanks are a bit lower because the base set does so much.
I'd buy some blanks, but since the base will support any layout I can imagine I'd want...I haven't.
Offline sean
  • Mechanical newb
« Reply #81 on: Tue, 29 September 2015, 19:08:57 »
It's a first world problem, I presume.
« Reply #82 on: Tue, 29 September 2015, 21:07:05 »
Kind of a shame there are no 2u keys, otherwise there could have been more interest in blanks from the Planck/Atomic crowd.
Offline njbair
    • nickbair.net
« Reply #83 on: Tue, 29 September 2015, 21:28:42 »
Trouble is, each size/row/color combination is its own MOQ, so adding one keycap size is actually 8 more line items.
My boards:
Offline njbair
    • nickbair.net
Re: [GB] Alpine Winter - 60% Alps DCS Keycaps (UPDATED BLANKS PRICING)
« Reply #84 on: Tue, 29 September 2015, 22:46:02 »
I just received pricing info for blanks. MOQ is still 25 per key color/size/profile, and pricing is as follows:
  • 1U: $0.73/ea.
  • 1.25U: $0.75/ea.
  • 1.5U: $1.49/ea.
Much cheaper than I had figured! So if you were on the fence about blanks, hopefully this will help you decide.
My boards:
Offline Hypersphere
« Reply #85 on: Wed, 30 September 2015, 12:06:39 »
Just checking. If I sign up for the 50 MOQ and the 100 MOQ is reached, I would be charged for the 100 MOQ price -- correct?
Offline njbair
    • nickbair.net
« Reply #86 on: Wed, 30 September 2015, 12:14:31 »
Correct. Unless you want to pay me more!
My boards:
Offline sean
  • Mechanical newb
« Reply #87 on: Wed, 30 September 2015, 13:16:27 »
Hey njbair, I just submitted a new form for:
19 Blue 1U, Row 1
3 Blue 1U, Row 2
4 Blue 1U, Row 4
I hope that didn't complicate anything.
Offline njbair
    • nickbair.net
« Reply #88 on: Wed, 30 September 2015, 14:09:22 »
19 Blue 1U, Row 1
3 Blue 1U, Row 2
4 Blue 1U, Row 4
No problem. I'll know to combine them. Thanks!
My boards:
Offline julayyy
« Reply #89 on: Wed, 30 September 2015, 18:12:10 »
This set looks amazing! I just need an alps keyboard now :(
Don't know if I want to get a v60 with matias keyswitches just yet but goodluck with this buy!  :thumb:
QuickfireTK MX Reds         v60 mini MX Clears
Offline olijuice
« Reply #90 on: Wed, 30 September 2015, 18:15:25 »
I just placed my order. Thank you for making this happen!
Offline Jersern
  • Australian Keyboard Modding and Repair Service
« Reply #91 on: Wed, 30 September 2015, 18:34:38 »
I'm looking for just the AEK2 space bar kit so if anyone with an order wouldn't mind adding a kit on that would be amazing. (I'll pay for the spacebars and shipping to me of course)
« Reply #92 on: Wed, 30 September 2015, 18:38:30 »
Of course I had to support this. Just put my order in and I'm excited for more custom Alps keycaps.
Offline cheddarbek
« Reply #93 on: Wed, 30 September 2015, 18:39:11 »
Alps is life.
Offline sean
  • Mechanical newb
« Reply #94 on: Wed, 30 September 2015, 23:31:39 »
In case anyone is wondering why I ordered 26 blanks (which is probably nobody), I plan on using the blanks to get full coverage on a TKL keyboard. It only costs $19 more and I could have saved a little more since the kit already comes with two row 4 1u blanks. Yes, I know this is supposed to be a 60% GB but I like to be creative. :D
I might order 8 row 1 grey blanks for the F1-F4 and F9-F12 keys to see if I like one looks over the other - but that depends on if njbair will hate me for submitting yet another order form.  :))
« Last Edit: Wed, 30 September 2015, 23:33:13 by sean »
Offline njbair
    • nickbair.net
« Reply #95 on: Wed, 30 September 2015, 23:48:57 »
GB leaders generally don't hate people for spending more money.
My boards:
Offline stoic-lemon
« Reply #96 on: Thu, 01 October 2015, 02:13:17 »
I was actually wondering what poeple are going to be doing with all the blanks. I didn't realize you could specify the row you wanted. Even so, there are some sizes which aren't available, so I assume you are just going to use regular keys with legends for those.
Offline sean
  • Mechanical newb
« Reply #97 on: Thu, 01 October 2015, 12:25:50 »
The escape, F keys, arrow keys, insert, delete, print screen, etc will all be blanks while the alphas and modifiers will be the regular keys from the gb. Actually now that I think about it I'll probably put a sadster on the escape key :)
Offline luckynet
« Reply #98 on: Thu, 01 October 2015, 22:11:34 »
if this were in SA it would make it the first of it's kind... which is kinda sweet as well :)
Realforce 104U - HHKB Pro 2 dental band - HHKB Pro 2 Hasu's bluetooth controller - CM novatouch silent mod - Royal Kludge Topre clones
Filco Magestouch 2 Brown - Duckyshine 9008s Brown - QFR white - Plum MX 96 Blue - KBT Race Red - SS 7G Black - Poker blue - ducky shine 69
IBM Model M SSK
Matias quiet pro - V60 matias clicky
Offline BlueNalgene
« Reply #99 on: Thu, 01 October 2015, 22:14:16 »
If I remember correctly, SP does not have the SA + Alps tooling.
