Author Topic: Thinking of modding these two boards I picked up...need some input.  (Read 1460 times)
Offline GeneralArrow
« on: Fri, 25 September 2015, 16:31:27 »
These might be alps switches, or some form of alps compatible switch
http://i.imgur.com/rD7CqRE.jpg
Not sure what type of switch this is, but I'm sure it's on top of a rubber dome as it feels incredibly mushy.
http://i.imgur.com/qTNAaQG.jpg
PS, also pretty new to these forums, and just getting into the mech side of things.
Re: Thinking of modding these two boards I picked up...need some input.
« Reply #1 on: Fri, 25 September 2015, 17:29:11 »
Both look like slider over rubber dome. The first one by NMB and sadly not Alps-compatible. The second keyboard looks like it was built by Fujitsu - and yes, those are usually very mushy.
