Author Topic: [SOLVED] White front print keycaps with Finnish/Swedish ISO layout?  (Read 9341 times)
Offline lautzki
« on: Sat, 26 September 2015, 14:42:39 »
Yo. Any idea where I could find a set of white, front-printed keycaps with Finnish/Swedish (Nordic) ISO layout? I have a QuickFire XT.
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1334
This is exactly what I want, but is apparently only available in US layout.
« Last Edit: Sun, 18 October 2015, 11:08:05 by lautzki »
Offline seville57
Re: White front print keycaps with Finnish/Swedish ISO layout?
« Reply #1 on: Sat, 26 September 2015, 17:32:38 »
I know that Ducky have a white ISO/Nordic keycaps set but in ABS and not frontprinted.
You can always take a look here: https://geekhack.org/index.php?topic=70781.0
« Last Edit: Sat, 26 September 2015, 18:00:16 by seville57 »
Offline lautzki
« Reply #2 on: Sun, 27 September 2015, 04:14:39 »
Blanks will suffice just fine, but I really prefer the textured feel of PBT.
« Reply #3 on: Sun, 27 September 2015, 04:59:36 »
The texture is not an inherent property of the plastic but of the mould... Although PBT tends to keep its texture longer, not having it worn off as easily as ABS.
You could get blanks of PBT and then apply the letters with water-slide decals (print on special paper, cut out and apply) or rub-on stickers ("gnuggisar"), if you could find them.
Offline lautzki
« Reply #4 on: Sun, 27 September 2015, 05:36:36 »
I see. The problem is that I can't find these white blank PBT caps in ISO layout anywhere...
Offline seville57
« Reply #5 on: Sun, 27 September 2015, 12:28:12 »
Welcome to the big problem of ISO layout, you can't almost not  find any  ISO/Nordic layout PBT keycaps sets.
All good lookin keycaps sets are in ANSI layout.
Here is some pictures of mine ISO/Nordic/English k-boards.
Duckys Nordic Grey/Blue laser ingraved PBT set on my Ducky Shine 3 English ISO layout k-board.
The Esc cap is a HKP Raven Smoke cap on this picture.
Ducky Shine 3 with Duckys PBT yellow ISO/Nordic Dyesub set.
The 2 black  "BEERBREAK" caps don't belong to the yellow set.
I solved mine never find any ISO/Nordic keycaps sets problem anywhere, I bought a ANSI k-board last year, got 5 ANSI k-boards now and never any problem to find any ANSI keycaps sets in blank, toprinted, frontprinted black, pink, yellow and so.
« Last Edit: Sun, 27 September 2015, 13:55:16 by seville57 »
Offline lautzki
Re: [SOLVED] White front print keycaps with Finnish/Swedish ISO layout?
« Reply #6 on: Sun, 18 October 2015, 11:13:30 »
Finally found the product I wanted from MAX Keyboard (http://www.maxkeyboard.com). White blank 105-key ISO layout keycap set + custom front-print service with Swedish layout.
Not PBT, but who cares. Looks awesome!
« Last Edit: Sun, 18 October 2015, 11:15:11 by lautzki »
