Author Topic: [Edited 1x] How do I look for keycaps? Where can I find them?  (Read 2684 times)
Offline Vozella
« on: Sat, 26 September 2015, 15:48:52 »
How do I look for keycaps? I'm specifically looking for black, blank, and PBT keycaps.
61 1x1
3  1.25x1
2  2x1
1  6.25x1
Edit: Sorry. I posted in the wrong sub forum. How do I move this?
Edit: Okay. On top of what I said above, I also want contoured keys.
I want to buy both Cylindrical and Spherical to try them both out.
I'm not just looking for links directly to buy keycaps. I want to learn how to look for them myself. How do I look for keycaps? Where can I find them?
« Last Edit: Sun, 27 September 2015, 17:34:48 by Vozella »
Offline njbair
    • nickbair.net
Re: How do I look for keycaps? Where can I find them?
« Reply #1 on: Sat, 26 September 2015, 21:36:21 »
I'm assuming you're looking for Cherry MX mount caps? Which profile are you looking for?
If you're okay with DSA profile you can get some at Pimp My Keyboard.
My boards:
Offline Vozella
« Reply #2 on: Sat, 26 September 2015, 23:41:44 »
What other profiles are there? I don't know what this means.
Offline do_Og@n
« Reply #3 on: Sat, 26 September 2015, 23:45:48 »
Oh you have only brushed the surface of mechanical keyboards.
Signature Plastics main website can shed some light on your question. There are a lot of profiles but the most common you'll across are:
OEM (most keyboards come with this profile of keycap)
DCS (almost the same as OEM but lower profile)
SA (tall flat profile)
DSA (short flat profile)
You also have different switch types but Cherry MX are the most common for beginners.
Offline ideus
  • Björkö.
« Reply #4 on: Sat, 26 September 2015, 23:45:58 »
Check these references, you would prepare a cup of coffee, have a seat in a comfortable couch and enjoy 12 hours of careful reading.
« Reply #5 on: Sun, 27 September 2015, 03:48:44 »
It might also depend if you want a full matching set, or just any random profile keycaps of the nominated sizes.
Offline KHAANNN
Re: [Edited 1x] How do I look for keycaps? Where can I find them?
« Reply #6 on: Mon, 28 September 2015, 10:14:35 »
Just get one of these and end your suffering: https://geekhack.org/index.php?topic=72609.0
Edit: Just saw the edit, you look for keycaps by stalking GH, GH GB's, GH classifieds, Reddit, mechmarket, by periodically and maniacally checking vendor websites etc.
