Author Topic: Keycaps Set  (Read 2097 times)
Offline Azzie
Keycaps Set
« on: Mon, 28 September 2015, 05:22:55 »
Hi!
I need help deciding wich set to buy that will work with  DayDream LED Cover.
I was thinking about PBT Double Shot Keycap Set - Black Translucent (Vortex) but in this review ,
reviwers says he has problems with keys not returning in position.
Also can some1 suggest good LEDs to go with that. I have Pok3r and i want to make Backlit keyboard
Thank you in advance!
Offline Wuzadi
Re: Keycaps Set
« Reply #1 on: Sun, 11 October 2015, 18:47:59 »
I have two sets of these, both white not the black ones and I've never had an issue with keys not returning to their positions. I however, have never tried out led covers...that could definitely make a difference I guess. Are you for sure putting covers on top of your leds? Oh and just a heads up, just as the pictures shows, the number row doesn't show the bottom legends depending on where your leds or positioned (top or bottom switch).
You met me at a very strange time in my life.
Offline zzyjayfree
Re: Keycaps Set
« Reply #2 on: Wed, 28 October 2015, 11:16:10 »
Funny that esc actually means opposite meaning of 入. But nice set for sure!
OTD 360 Corsa w/ Nixdorf, OTD 356.2 DGE, Matrix 1.2, Matrix 2.0, Matrix Abel, Skog, Dolphin, EM7, Lynn Pad, Plank, LZ-RE, EqualZ, Orion v2, Octagon v2, Viper v2, Tank, Mira, Mira SE, Moon, Camp 225, Let's Split, HHKB, RealForce, Infinity Ergo, Cherry 3700, DolchPac, Nixdorf, Model M, Filcos.
