Author Topic: Ergodox case options  (Read 1276 times)
Offline profet
« on: Fri, 02 October 2015, 20:39:09 »
So I've begun sourcing the parts to build myself an Ergodox.
I've got everything shipping to me as of today except for keycaps and a case.
My issue is trying to find an online store to source a case.
I like the mechanicalkeyboards.com cases except they only seem to have the full palm cases in stock. How frequently/infrequently do they replenish stock of the standard cases?
What are my alternatives? I'd really prefer to get a case that is ready made as I don't have access to a laser or 3d printer.
Bringing custom Ergodoxes to the masses.
My heatware: http://www.heatware.com/u/102649
Online Findecanor
Re: Ergodox case options
« Reply #1 on: Sat, 03 October 2015, 08:49:42 »
There are several options available at FalbaTech in Poland.
AFAIK, FalbaTech is the only one who makes machined PVC cases. A metal plate would be separate and you could use through-hole diodes. You could also go without a plate and use PCB-mounted switches (switches have two stabilising pins) and optionally: PCB-mounted stabilisers if your PCB is of such a revision.
FalbaTech also has acrylic cases (like what Massdrop used to have) and 3D-printed cases (which I think is what Dox made for himself originally).
I am not sure that the acrylic cases support stabilisers - the ones at Massdrop didn't, because of a bug in the layout.
