Author Topic: Adding LED's to roccat ryos  (Read 3458 times)
Offline iludez
« on: Sat, 03 October 2015, 03:48:12 »
So i got a very cheap brand new roccat ryos with mx blacks.
There is a roccat ryos pro and a roccat ryos.
They seem identical im wondering if i can just pop in 3mm leds?I know its not much info but thought some of you guys might know.
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
Re: Adding LED's to roccat ryos
« Reply #1 on: Sat, 03 October 2015, 04:21:12 »
If you already have it, your best bet would be to just open it up and see if there's holes/pads on the PCB for LED's. If there is you should double check if there are resistors already soldered on to the PCB.
GON NerD TKL DTA Edition
Offline iludez
« Reply #2 on: Sat, 03 October 2015, 04:24:46 »
Cool cheers wll do that.I assume the resistors are the little rectangular boxes near the holes?
Offline iludez
« Reply #3 on: Sun, 04 October 2015, 00:28:10 »
Found this image.Can anyone shed some light on if i can add leds to it?im thinking not.
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #4 on: Sun, 04 October 2015, 06:46:06 »
assuming your PCB is exactly the same as this one then there are definitely holes for LED's but the image is very blurry so i can't tell if there are resistors but it doesn't look like it so you'd have to solder on some SMD diodes as well.
« Reply #5 on: Sun, 04 October 2015, 08:21:06 »
assuming your PCB is exactly the same as this one then there are definitely holes for LED's but the image is very blurry so i can't tell if there are resistors but it doesn't look like it so you'd have to solder on some SMD diodes resistors as well.
Agreed, looks like they've put solder on all the pads but no resistors.
@iludez - You'll probably need to remove the solder from the LED holes using a soldapult or desoldering braid but if the case isn't too tight to the back of the PCB you can just add the resistors on top of the existing solder.  Be sure to use a bit of fresh solder or some flux and make sure it all melts so you get a good joint :)
Offline iludez
« Reply #6 on: Sun, 04 October 2015, 14:09:39 »
If you click on the image it does zoom in.I thought the little things beside the switches were resistors?Sure looks like it to me.
Stoked i can add leds though very happy.If i do add smd resistors where is the optimal place?
Offline iludez
« Reply #7 on: Sun, 04 October 2015, 14:14:11 »
Ah nevermind i see where the resistors should be.Can you guys tell me what size and wattage resistors should be?
« Reply #8 on: Sun, 04 October 2015, 14:15:45 »
The little things you can see are diodes (you can tell because they always have a line across them at one end so you know which way they go)  The LEDs go in the two small holes below the big black dots and the resistors for them go vertically on the two pads slightly to the right of them :)
Offline iludez
« Reply #9 on: Sun, 04 October 2015, 14:29:12 »
Yep i derped and realised afterwards what i was actually looking at.
Any idea on resistor type?
« Reply #10 on: Sun, 04 October 2015, 14:42:46 »
They are sold by size, usually they use 0603 on keyboards but looking at that pic they look smaller than the switch pin holes, so I'd guess they're probably 0402 - I would wait for someone to confirm that though as I'm no expert.
The other important spec is the resistance which would depend on the colour and model of LED you're using and how it's wired up (which as someone else made it we have no idea)  For testing purposes assume they're on the 5v from USB and use the specs of whatever LEDs you have in this calculator - if you get it wrong they'll be too dull so be sure to test one before filling up the whole board!
Offline iludez
« Reply #11 on: Sun, 04 October 2015, 21:00:58 »
Really appreciate the replies guys.
So looks like ill go ahead and order some 3mm uv leds and wait for someone to comment on the correct resistors?
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #12 on: Mon, 05 October 2015, 02:23:57 »
That'll help you find the resistor value (it'll change depending on the color of the led) and the size is fairly easy to figure out.
Check out winkeyless.kr/en or gonskeyboardwork.com, I think they have the size of the smd resistors written down.
Offline iludez
« Reply #13 on: Mon, 05 October 2015, 02:44:31 »
Thanks for that info Evo.
So i assume id go with the 820ohm chip resistor for pink/white leds.
This is the purple led specs
 RoHS : Yes
Life Rating : 100,000 Hours
Emitted Colour : Purple / UV
Size (mm) : 3mm
Lens Colour : Water clear
Peak Wave Length (nm) : 395 ~ 405
Forward Voltage (V) :  3.2 ~ 3.8
Reverse Current (uA) : <= 30
Luminous Intensity Typ Iv (mcd) : 3000(Typical) ~ 5000(Max)
Viewing Angle : 20~25 Degree
Max Power Dissipation(PM): 80mW
Max Peak Forward Current(IFP): 75mA
Max Continuous Forward Current(IFM): 20mA
Lead Soldering Temperature : 240 Degree (<5Sec)
Operating Temperature Range : -25 ~ +85 Degree
Preservative Temperature Range : -30 ~ +100 Degree
