Author Topic: Can you use tape as a stabilizer holder?  (Read 1418 times)
Offline snarfarlarkus
« on: Mon, 05 October 2015, 20:50:04 »
Hi guys, my  omnikey 102 wit blue alps has one stabilizer holder thing lost on the spacebar. I cant use the spacebar without it obviously so I am just asking you guys what I could use instead of the stabilizer holder? Maybe tape would work? Cheers
Re: Can you use tape as a stabilizer holder?
« Reply #1 on: Mon, 05 October 2015, 20:54:44 »
Also, how do I take out the stabilizer holder out of another key? Such as the numpad enter. Thanks!
Online fohat.digs
« Reply #2 on: Mon, 05 October 2015, 21:08:10 »
They just pull out of a rectangular hole with needle-nose pliers. But, as I remember, the spacebar ones have longer "mouths"
If you are talking about the ones built into the key. The hold-downs in the front plate are all the same.
For postage to Oz I will send you a few. PM me.
- D Trump 2026-10-24
« Reply #3 on: Mon, 05 October 2015, 21:45:25 »
Pm'd, fohat!
