Author Topic: Missing keycaps?  (Read 2200 times)
Offline KarimDK
  • Humorous and curious
    • my heatware
Missing keycaps?
« on: Tue, 06 October 2015, 13:45:47 »
 Hi everyone !
So yah. After a bit time enjoying these stuffs,I figure out that  I sometimes  have problems with rare sets. They missed some caps and I think that was from PO.
How these missing keycaps affect to the sets value?
 Is there any chance to collect them like customize single caps for my sets?
Much appreciated !
« Last Edit: Tue, 06 October 2015, 13:48:48 by KarimDK »
<3 <3 <3 be patience,I'm coming to buy stuff
Re: Missing keycaps?
« Reply #1 on: Tue, 06 October 2015, 21:05:31 »
That would depend on the set, and which keycaps are missing.
If it is a custom colour from GMK, for example, you are unlikely to get them to make a single keycap.  You'd have to hope that someone had purchased a few extra sets and was willing to split the sets to complete your set.
If they are more common, or at least more accessible, such as DCS or DSA keycaps from PMK, you could probably ask nicely and they might make you some.
Anything else you'd need to identify the set and missing keycap/s.
Offline alienman82
« Reply #2 on: Tue, 06 October 2015, 21:55:17 »
removed.
« Last Edit: Thu, 01 March 2018, 17:12:08 by alienman82 »
Offline KarimDK
    • my heatware
« Reply #3 on: Wed, 07 October 2015, 21:15:58 »
Thanks for answering my question pretty clear.
I think I got some experience buying stuffs now and should be careful with those missing caps.
Offline KarimDK
    • my heatware
« Reply #4 on: Wed, 07 October 2015, 21:17:03 »
Not a missing cap, but I always wanted to get a full length right GMK Dolch right shift, so I could use the OG cherry ones with a tenkeyless.  Contacted Originative, and they hooked me up.  The more communication, the better.
Yes, you are right. It would be nice to communicate :D
