Author Topic: Why no 3 color combination sets?  (Read 2055 times)
Offline ManicMatt1125
« on: Tue, 06 October 2015, 17:39:25 »
So I am attempting to put together a pokemon key set, and in doing so I came up with a great idea. As is the case with all my great ideas, I'm sure it wasn't implemented for a reason but I am curious as to why.
Why have there not been any keysets with 3 colors, 2 colors as the "base" and the third color being interchangable. For example, see my thread here:  https://geekhack.org/index.php?topic=75774.0.
113019-0113021-1113023-2
You sell the base set, and then you sell the other 2 colors as add ons, or even just sell it all as one?
I mean, common sense tells me that yes, while the theme will remain the same the fact that you can "hot swap" between three different colors would be highly desierable. What am I missing here? Can it be no one has come up with such an idea? Or, has the idea already been shot down by some logic unknown to me? If I gander a guess I will probably say it has to do with price, all of which is completely new to me.
« Last Edit: Tue, 06 October 2015, 17:41:11 by ManicMatt1125 »
Re: Why no 3 color combination sets?
« Reply #1 on: Tue, 06 October 2015, 17:41:06 »
Deep Space had different options for mods.  The problem is that it becomes increasingly difficult to hit MOQs as you add more.
« Reply #2 on: Tue, 06 October 2015, 17:43:54 »
Ah, so MOQ would be three times the normal amount with the add-ons, Does anyone have any idea, ball park roundabout what the price would be for a set such as this? Iwould probaly make it a TKL set so it would contain 66 extra keys.
Offline MaNiFeX
  • Wu Tang Killa Keebs
    • MaNiFeX.net
« Reply #3 on: Tue, 06 October 2015, 19:17:23 »
From SP?  I submitted a really simple colorway, and it ended up being around $40 for base and $35, before quantity is reached.  It gets cheaper the more people buy.
« Reply #4 on: Tue, 06 October 2015, 19:44:10 »
Any idea on what that would translate to for GMK? I know they are typically more expensive, but Im not sure how much more
