Author Topic: Identify these two IBM keyboards  (Read 7345 times)
Offline blueangel2323
« on: Tue, 06 October 2015, 22:53:00 »
What model are these IBM keyboards? Are they worth anything?
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
Re: Identify these two IBM keyboards
« Reply #1 on: Tue, 06 October 2015, 23:02:22 »
Both rubberdome.  Top one is a Model A.  (Newer model with Windows keys...)
Bottom one is a newer rubberdome.
« Last Edit: Tue, 06 October 2015, 23:31:21 by Snowdog993 »
« Reply #2 on: Tue, 06 October 2015, 23:22:23 »
Too bad. I knew they didn't look anything like the famous Model F and M but I was hoping there were some rare mechanical keyboards made by IBM that I didn't know about. Thanks for the info.
« Reply #3 on: Wed, 07 October 2015, 07:32:02 »
The top one is an 8923 and is a very nice and well-built rubber dome.
The bottom one looks like it has a Unicomp LED label and is probably newer.
- D Trump 2026-10-24
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #4 on: Wed, 07 October 2015, 09:14:38 »
Yeah the 8923 is easily one of the heaviest RD boards I've found yet, it comes with a steel plate and everything. They feel pretty OK as far as rubber domes go. Nothing really special, but it's better than whatever they use in offices nowadays.
Offline Snowdog993
« Reply #5 on: Wed, 07 October 2015, 10:24:50 »
Have you guys even seen a Model A?
Offline SamirD
« Reply #6 on: Wed, 07 October 2015, 11:15:40 »
Both of those keyboards are just some IBM rubber domes, although the top one has had some accolades on here as being 'not that bad'.  Personally, I hate it and quickly replaced all 8 of ours with Ms.  But I still have them.
I have quite a few of the bottom one as well, mainly in black.  They were used a lot on the 'Netvista' series of IBM computers that were used on a lot of hotel property management systems (where I got them when these systems were upgraded or taken out of service).
Is that still a rubber dome?  It does look a bit like the top one, but the keycaps look smoother.
Offline Snowdog993
« Reply #7 on: Wed, 07 October 2015, 11:21:10 »
Yes, the Model A is a rubber dome.
Offline SamirD
« Reply #8 on: Wed, 07 October 2015, 11:38:10 »
How does the 101 layout version compare with the one in the top photo with the windows keys?
Offline Snowdog993
« Reply #9 on: Wed, 07 October 2015, 11:43:23 »
After reading on the 8923, I suppose they are similar keyboards.  They both apparently have metal backplates on them.  The only difference (I suppose) is who made them.  The Model A is made for IBM by Lexmark.  I don't know about the 8923.
« Last Edit: Wed, 07 October 2015, 11:45:51 by Snowdog993 »
Offline SamirD
« Reply #10 on: Wed, 07 October 2015, 12:36:30 »
I'll have to check the next time I'm back near mine, but I'm suspecting it would also be Lexmark.
Offline Snowdog993
« Reply #11 on: Thu, 08 October 2015, 18:57:52 »
Did you check it?  I am kind of curious about this.  I think they went to another manufacturer with the Windows keyboards about that time.
Offline niubio
« Reply #12 on: Thu, 08 October 2015, 19:28:07 »
Isn't this "winkey Model A" made by Chicony?
link, link2, link3
"E8HKB" in FCC ID...
« Last Edit: Thu, 08 October 2015, 19:30:06 by niubio »
Offline Snowdog993
« Reply #13 on: Thu, 08 October 2015, 20:30:13 »
link, link2, link3
If it had Windows keys, I would agree.  Seems that IBM went with some other manufacturers in Thailand to make them.
Edit: So the transition was somewhere between 1995 and 1996.  Interesting stuff.
« Last Edit: Thu, 08 October 2015, 20:31:50 by Snowdog993 »
Offline SamirD
« Reply #14 on: Thu, 08 October 2015, 22:51:05 »
It will be a few weeks before I'm back where I can. :(  But made in Thailand seems to ring a bell for some reason.  It's been almost 2 decades since I looked at the labels on those.
