Author Topic: Custom HHKB style 60% case with standard 60% custom pcbs support  (Read 5966 times)
Offline Vaun
  • ¯\_(ಠ_ಠ)_/¯
« on: Wed, 07 October 2015, 05:02:13 »
Basically a Duck Viper style case that supports the standard custom 60% pcbs and plates. Why doesn't this exist? WHY!?
Offline joey
Re: Custom HHKB style 60% case with standard 60% custom pcbs support
« Reply #1 on: Wed, 07 October 2015, 05:18:54 »
How would the pcb fit?
Offline Vaun
  • ¯\_(ಠ_ಠ)_/¯
« Reply #2 on: Wed, 07 October 2015, 05:22:15 »
A simple 2 layered design. Basically take a low profile case like the one Tex makes, but with a little more margin for screw holes, and make a top layer for it. Simple.
Offline sth
  • 2 girls 1 cuprubber
« Reply #3 on: Wed, 07 October 2015, 05:25:50 »
would be pretty easy to mod a tex acryl case and get a top layer cut for it.
damn why didn't i think of that before i missed the most recent massdrop buy for that case!!!
Offline Vaun
  • ¯\_(ಠ_ಠ)_/¯
« Reply #4 on: Wed, 07 October 2015, 05:44:16 »
I know! With that case you can get some funky light effects like the Duck Orion case aswell. The only concern I have for that case is if there's enough material at the top for screws?
Edit: Might aswell get good plate and sip sockets so one can glue the whole thing.
« Last Edit: Wed, 07 October 2015, 05:48:19 by Vaun »
Offline joey
« Reply #5 on: Wed, 07 October 2015, 05:44:58 »
http://winkeyless.kr already sell HHKB style cases:
« Last Edit: Wed, 07 October 2015, 05:48:16 by joey »
Offline azhdar
  • Praise the AZERTY god
Azerty Propagandiste
Offline sth
« Reply #7 on: Wed, 07 October 2015, 05:46:28 »
i think they only work with their sandwich-style plates though. would be nice to have an option that works with a poker-style plate.
Offline Vaun
  • ¯\_(ಠ_ಠ)_/¯
« Reply #8 on: Wed, 07 October 2015, 05:51:16 »
I'm also after high edges, aluminum and no visible screw holes so Winkeyless and GON's versions simply doesn't do it for me.
Offline joey
« Reply #9 on: Wed, 07 October 2015, 05:54:31 »
Download a CAD program and get to work!
Offline sth
« Reply #10 on: Wed, 07 October 2015, 06:20:48 »
sorry for potato pic and caveman drawing, but something like this could be made to fit onto any 60% case with a big enough bezel:
Offline Vaun
  • ¯\_(ಠ_ಠ)_/¯
« Reply #11 on: Wed, 07 October 2015, 06:22:40 »
The only thing I would change is the screws, I'd put those from the bottom and not have them pass trough the top layer.
Offline sth
« Reply #12 on: Wed, 07 October 2015, 06:27:45 »
good call :) cleaner style. it would require a fairly thick top layer but i think 5-6 mm would be doable to get at least 3-4 threads engaged, depending on the pitch of the screws used.
i might actually try to make something like this and have it cut next month when i get paid again.
Offline Vaun
  • ¯\_(ಠ_ಠ)_/¯
« Reply #13 on: Wed, 07 October 2015, 06:48:45 »
5-6 mm thick layer would make the edge in line with the bottom of the keycaps and look fantastic. You understand your responsability of keeping this thread updated with your results right? ;)
Offline sth
« Reply #14 on: Wed, 07 October 2015, 12:17:51 »
bah!!! i'll try. remind me if i forget ;)
Offline Vaun
  • ¯\_(ಠ_ಠ)_/¯
« Reply #15 on: Tue, 20 October 2015, 04:25:14 »
Have you forgotten? ;)
Offline sth
« Reply #16 on: Tue, 20 October 2015, 08:07:42 »
nope just too busy :(
