Author Topic: Cherry LPOS  (Read 5256 times)
Offline cogito_ergo_sum
Cherry LPOS
« on: Thu, 08 October 2015, 12:53:06 »
Has anyone used the Cherry LPOS keyboard?
http://cherrycorp.com/product/lpos-large-point-of-sale-keyboard/
It seems to offer a lot of programmability, though I have not found a detailed description of precisely what it can do.
Is it a good alternative to the Kinesis Advantage and the Truly Ergonomic Keyboard? Can it be programmed on computer A and moved to computer B without installing drivers or other software on computer B?
« Last Edit: Thu, 08 October 2015, 12:54:48 by cogito_ergo_sum »
Offline davkol
  •  Post Editing Timeout
Re: Cherry LPOS
« Reply #1 on: Thu, 08 October 2015, 13:50:52 »
Mal-2 over at Deskthority uses a matrix Cherry G86.
It has essentially nothing to do with Kinesis Advantage or TECK, except it's a keyboard too.
Re: Cherry LPOS
« Reply #2 on: Fri, 09 October 2015, 00:22:21 »
The website says it has "unlimited programmability" of all keys (with up to 131 keys) with 3 layers. However, I've not found a user manual or a review of it. I'd like to know how/if it compares to the macro ability of other boards.
I may have to contact the manufacturer. I have feeling they won't understand how I want to use it, since they appear to be geared toward industrial customers.
Re: Cherry LPOS
« Reply #3 on: Sat, 10 October 2015, 11:40:11 »
I downloaded the Cherry Tools programming utility. I am posting the results in case anyone might be interested.
There are 3 programmable layers, they are not reached by toggle. You have to hold down a modifier (ctrl or shift) and press the key to access layers 2 and 3. (Perhaps a toggle could be jerry-rigged by programming a key with modifier-down-stroke and modifier-up-stroke, but I am not going to buy the product to find out.)
Layers 2 and 3 can only be used by storing macros on the computer. Only layer 1 can be written to the board itself.
At home, I can duplicate the LPOS's functionality with Autohotkeys. At work, the Kinesis is likely still better because of the design. However, the LPOS offers much easier programming, even restricted to 1 layer.
Offline SamirD
Re: Cherry LPOS
« Reply #4 on: Fri, 16 October 2015, 18:43:23 »
I was wondering how this was accomplished, so thank you for the update!
Offline Giorgio
Re: Cherry LPOS
« Reply #5 on: Sun, 18 October 2015, 14:54:46 »
It doesn't use cherry mx switches though....
Offline SamirD
Re: Cherry LPOS
« Reply #6 on: Mon, 19 October 2015, 21:36:13 »
Good to keep in mind!
Offline Kola93
Re: Cherry LPOS
« Reply #7 on: Sun, 25 October 2015, 21:55:50 »
The keyboard looks nice, but the keycaps don't seem to be very good ones. :(
Offline davkol
Re: Cherry LPOS
« Reply #8 on: Mon, 26 October 2015, 09:57:47 »
Probably thick POM, i.e., much better than 99 % of the market.
