Author Topic: Ergodox litster acrylic case plate for 80 keys  (Read 2742 times)
Offline profet
« on: Fri, 09 October 2015, 08:12:09 »
Is the litster acrylic case compatible with 80 keys? =
Is there a plate available somewhere that supports 80 keys for this design?
Bringing custom Ergodoxes to the masses.
My heatware: http://www.heatware.com/u/102649
Offline yoobe
  • Yoobe
Yoobe
ErgoDox - Mx Brown
Filco Minila Air - Mx Red
RedScarfII+ VerC - Gateron White
Offline profet
Re: Ergodox litster acrylic case plate for 80 keys
« Reply #2 on: Fri, 09 October 2015, 11:52:00 »
check on this site ?: http://falbatech.pl/prestashop/index.php?id_category=18&controller=category&id_lang=2
Yeah... I see an 80 switch plate for their CNC case... but not one for the acrylic litster cases.
Offline cwils0n
  • twiggletwaggle
« Reply #3 on: Fri, 09 October 2015, 11:59:33 »
Narcoleptic_Bat on reddit makes acrylic litster cases.  I have one and it's top notch.  Here's his sale post:
https://www.reddit.com/r/mechmarket/comments/3edl2m/ustxhlaser_cutter_acrylic_experience_cutting/
I believe he makes them to order and I would think an 80 key version is doable.  Maybe send him a message and ask.
Offline profet
« Reply #4 on: Fri, 09 October 2015, 12:23:10 »
Offline cwils0n
  • twiggletwaggle
« Reply #5 on: Fri, 09 October 2015, 13:43:01 »
No problem at all and GL with your build.  Don't forget to post pics if you can!  :thumb:
Offline profet
« Reply #6 on: Fri, 09 October 2015, 15:24:07 »
Waiting on a reply... but I assume he's going to want the dxf files for the 80 key version.
Do these exist? Again, I'm looking for an 80 key version of the 3rd plate of Litster's acrylic case.
Any help would be greatly appreciated.
Offline cwils0n
  • twiggletwaggle
« Reply #7 on: Fri, 09 October 2015, 17:15:41 »
Offline profet
« Reply #8 on: Fri, 09 October 2015, 18:04:00 »
It looks like that's for the PVC case.  I'll message czarek and see if he has a dxf file for the litster design.
