Author Topic: Hi From TN  (Read 2072 times)
Offline tjcertified
Hi From TN
« on: Fri, 09 October 2015, 21:22:33 »
Hello all,
I am a keyboard enthusiast from Tennessee. I have tried 5 keyboard, and am currently in possession of two. I haven't really strayed into custom keycaps yet, but that is about to change. I began with a Monoprice MX-Blue, a cheap entry point, and loved it. I sold that one to a friend and tried the CODE Keyboard by WASD with Mx Clear switches. I enjoyed it, and still have it, but am looking to sell soon. When I saw the Corsair RGB K70 came out, I grabbed one with Mx Browns, but I own a Mac, and the lighting program didn't work at all, so that one was a bust. I sold it and went back to the CODE. Recently, after reading more about Topre switches, I had to try one. My wife had finally forgiven me for the prior keyboard purchases, so I felt it was about time to tick her off again. I tried the HHKB Pro 2. LOOOVED the switch feel, but the format ultimately didn't match my needs. Turns out I really like my arrow keys. I have been learning to use the top row for numbers, though, and decided I could go TKL, so a few days ago, I purchased the NovaTouch TKL. I like it, but the feel isn't quite the same as typing on the HHKB. I will probably keep it for a bit and see if it grows on me, but it honestly feels a bit spongy. That's where I am now though. I have also tried the IBM Model M as a buddy of mine from a previous employer had several, but he wasn't willing to part with it. So far, Topre is by far my favorite.
A bit long, I know, but I wanted to give my history. Nice to be a part of the group.
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
Re: Hi From TN
« Reply #1 on: Fri, 09 October 2015, 21:42:35 »
Welcome. :)
You have quite the history for someone with their first post! It is always good to have and idea on what you like and don't like. I myself have never tried true Topre. I do have a Noppoo clone, which I don't particularly care to type on. People really seem to love the HHKBs and the Realforce boards. Perphas Realforce is something that would fit your Torpe love and alievate the issues with the Novatouch.
I also started with a CODE w/ Clears and a few boards with MX Blues. I loved them Blues, but the loudness in the office was probably a bit too much. I switched to Gateron linears and I love those. There are so many switch choices it can be overwhelming sometimes.  :-\
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
Re: Hi From TN
« Reply #2 on: Fri, 09 October 2015, 21:55:48 »
Not if you know what choice works for you.
*wink*
Offline tjcertified
Re: Hi From TN
« Reply #3 on: Fri, 09 October 2015, 22:38:58 »
*wink*
Exactly! I really enjoyed the switches on the HHKB. I went back to the Mx Clears and immediately switched back until I got the NovaTouch. It looks like Topre is the future for me. I hate that there aren't as many key cap options for it, but the NovaTouch kind of fixes that.
Offline Belfong
Re: Hi From TN
« Reply #4 on: Sat, 10 October 2015, 01:27:58 »
Welcome to Geekhack! Another Topre lover! One of us:)
Re: Hi From TN
« Reply #5 on: Sun, 11 October 2015, 02:50:43 »
You are trying a variety of keyboards - that's excellent!
For many this is difficult, if now downright impossible, and some people spend years searching for their ideal keyboard.  Others find their perfect keyboard on their first purchase (or perhaps like their first keyboard enough that they don't even want to try another one).
But trying as many different switches and keyboards as possible will allow you to either narrow down your selection, or to collect just the keyboards that you like.
I have liked almost every keyboard I have, and so far kept all of them.  I rotate between them quite often, at work too, and the change in switch and layout can be refreshing.
