Author Topic: Does a billiard pool ball feel better than the stock L Trac trackball?  (Read 8137 times)
Offline snarfarlarkus
I just received my track ball from Massdrop (After such a loooong wait) and the ball feels a bit light and almost 'cheap' so I was wondering if I could replace it with a pool ball? Is it 2.25"? or 2.5"? And if anyone out there has tried it, is it an upgrade?
Offline fanpeople
Re: Does a billiard pool ball feel better than the stock L Trac trackball?
« Reply #1 on: Tue, 13 October 2015, 03:39:05 »
I changed mine out with a pool ball, I can't really tell the difference.
Offline njbair
    • nickbair.net
« Reply #2 on: Thu, 15 October 2015, 15:58:21 »
I am really surprised to hear that. I've never considered the L-Trac to have a light feel.
I think the stock black ball really is just an unpainted billiard ball, so you won't notice a difference.
My boards:
« Reply #3 on: Thu, 15 October 2015, 16:28:25 »
Yeah maybe its just me? Are there replacement balls out there? To make it feel different?
Offline njbair
    • nickbair.net
« Reply #4 on: Thu, 15 October 2015, 16:30:23 »
Not that I know of. What in particular is the issue? Did you know you can change the speed? I think the settings are 400, 800, and 1600 DPI. I forget which two buttons you click to change it.
My boards:
« Reply #5 on: Thu, 15 October 2015, 16:41:59 »
I find the stock ball has more grip and rolls smoother than a pool ball. The pool ball felt a little slicker and rolled a bit rougher
Offline njbair
    • nickbair.net
« Reply #6 on: Thu, 15 October 2015, 17:27:59 »
I find that when I clean the ball it feels rougher. I think the skin oils help it to roll more freely at weird angles. Have you used the billiard ball long enough to build up some oils on the surface?
My boards:
« Reply #7 on: Thu, 15 October 2015, 17:49:15 »
I think I used the billiards ball for like 3-4 months straight?
Offline njbair
    • nickbair.net
« Reply #8 on: Thu, 15 October 2015, 17:51:11 »
Hmm OK then. It probably only takes less than a week to build up.
Not sure why the one you used felt different, unless it had some weird lacquer on it or something.
My boards:
Offline keshley
    • Blog n stuff
« Reply #9 on: Fri, 16 October 2015, 08:04:10 »
IIRC, the L-Trac ball is actually made by a billiard ball company. Don't remember the name offhand. So yes, it pretty much IS a pool ball already.
I think the only way anybody will actually notice a difference is to use a higher quality cue ball, like a Super Aramith. Suppose it doesn't have to be a cue ball, but they're easier to buy as a single :)
After that, its likely placebo.
HHKB Pro 2       Pok3r
« Reply #10 on: Fri, 16 October 2015, 08:11:44 »
Maybe that's why my pool ball feels off. It was very used and I picked it up for cheap.
Offline njbair
    • nickbair.net
My boards:
Offline Kola93
« Reply #12 on: Mon, 26 October 2015, 03:04:00 »
This is very interesting information! I wonder if their newer translucent ball is also a billiards ball. ^-^
Offline mrgoldenzombie
  • Topre is cool I guess....
« Reply #13 on: Sat, 31 October 2015, 00:38:29 »
Does it feel smother?
O-Ringed Black RealForce 87u  | O-Ringed Novatouch with Miami PBT
